my fu*ken power steering went out yesterday
anyone have this problem???? theres oil in the reservoir
and it seems like it goes on and off
just curious- have you done any burnouts and cut the wheel?
I would visit the dealer, if you still are under the full warranty definately go.
The reason i ask...
Is because when you cut the wheel, the power steering pump - at high rpms - will produce alot of power assist. It isn't really designed for this, and usually grenades. Has happened to many old pals back in the HS days.
rarejdm.com
I was wondering if having larger, wider wheels would cause extra wear on the power steering pump? Not saying it's directly related to this, just curious if anyone knows?
Quote:
There are aftermarket powersteering coolers out there that are made for wider tires and people who go autoxOriginally Posted by zackt69
