Diconnected driverside air bag
Old Aug 24, 2006 | 01:00 PM
K-S-W's Avatar
I took my seat out to fix adj. controls. Dissconected air bag for driver's seat, now my airbag light want stop flashing. Everything is now connected, but still flashing. I've already searched and could not find how to fix this. Help me please, I dislike the dealer.
Thanks, K-S-W
Old Aug 24, 2006 | 02:08 PM
cato's Avatar
SouthernComfort Moderator
Try reseting the computer?
Old Aug 24, 2006 | 02:15 PM
abcquackyxyz's Avatar
try restting the computer. I would suggest removing the battery and pump brake lights a couple of times. The pedal method might work too but i would do the full drain no power style since it is your air bag.
Old Aug 24, 2006 | 02:18 PM
ohh yeah checked the service manual and you should check the fuse for the airbag module
Old Aug 24, 2006 | 02:23 PM
ttrank's Avatar
Grocery getter
You need to reset the airbag module. I had the same problem when I put in my coupe seats.
Get in the car and turn the ignition (don't start) on for ~8 seconds the car will do a check and the airbag light will come on solid. As soon as it goes off (but before it flashes) turn it back off. Repeat this 3-5 times and it will reset your airbag system.
Old Aug 24, 2006 | 03:42 PM
K-S-W's Avatar
Thanks a bunch fellas. You guys are a great help. TTrank it worked horray.
Later, k
Old Aug 24, 2006 | 04:29 PM
DieselX's Avatar
G team to the rescue!
Old Aug 24, 2006 | 06:24 PM
ttrank's Avatar
Grocery getter
Glad to help!
It took me a while to figure it out on mine.
Old Sep 4, 2006 | 10:37 PM
NinivTA's Avatar
I had just ran into the same problem, thanks a lot man, really helped me out!
Old Sep 5, 2006 | 08:46 AM
1dannyboy's Avatar
The airbag light started doing this yesterday after I moved my seat forward.... I am going to try this before taking it to the stealership...
Old Sep 5, 2006 | 01:40 PM
ttrank's Avatar
Grocery getter
If you didn't disconnect anything and the light came on you should check under your seat to make sure it didn't get caught and come unplugged. Then do the reset.
Old Sep 5, 2006 | 01:46 PM
Msedanman's Avatar
O.F. Administrator
Don't forget our DIY/FAQ forum, everyone......the AirBag reset is there too.
AIRBAG LIGHT RESET.
C.
Old Sep 5, 2006 | 01:49 PM
ttrank's Avatar
Grocery getter
That was where I found it when I put my coupe seats in.
Old Sep 14, 2006 | 03:35 AM
dvsmeth0dz's Avatar
Just recently my passenger airbag light would turn on then off. I've never messed around with my seats such as taking them out, would it work if i just resetted it?
Old Sep 14, 2006 | 02:09 PM
ttrank's Avatar
Grocery getter
It might. The same module controls them. The reset is not just for the seats.
