Problem: Hood release not working
Old Aug 26, 2006 | 07:52 PM
BaByBoY779's Avatar
I have a 2003.5 G35 Sedan and just noticed that my hood release switch under the dash does not work - therefore, I am unable to pop the hood. Any help would be most appreciated.
Thanks.
Dave
Old Aug 26, 2006 | 08:12 PM
ttrank's Avatar
Grocery getter
Did the cable come loose from the release switch? Does it still have the same amount of resistance as before?
Old Aug 26, 2006 | 09:13 PM
BaByBoY779's Avatar
No, not the same amount of tension as before. You can pull the switch without any pressure or cable releasing. Is there an easy way to fix this?
Old Aug 26, 2006 | 09:21 PM
ttrank's Avatar
Grocery getter
Have someone push down and pull up on the hood as you pull the lever. It may just be stuck.
Old Dec 10, 2010 | 07:47 PM
bigjee's Avatar
Sorry to resurrect an old thread but does someone know if i have to go the dealership to get the hood release fixed or can a local mechanic do it?
Thanks.
Old Dec 12, 2010 | 05:36 AM
Blue Dream's Avatar
I drove ttrank's car solo
Local mechanic should be able to fix it.
Old Dec 12, 2010 | 09:39 PM
bigjee's Avatar
Thanks for the feedback.
I'll post back and tell how everything goes.
I'm taking the car in next week to the mechanic (fingers crossed)
Old Dec 16, 2010 | 02:05 PM
bigjee's Avatar
Update:
I was driving a fair bit today (usually I dont drive my car more than 10-20 miles at a time since work and everything else is really close for me).
Had been on the road for about 2 hours so I just decided to reach down on the hood release lever and see if its still broken and freely moving.
And viola! it was back to normal.
I haven't had it looked at by the mechanic yet so that saved me a trip.
I think the cable had frozen some how since last week the temps had hit 30 below and it was freezing cold. I think that had something to do with it.
And now that I had been driving around for 2 hours the interior of the car had warmed up nicely and I guess that restored the function of the hood release lever.
Just wanted to share my experience.
Hope this helps someone out.
Old Jun 25, 2011 | 04:45 PM
Da_twinky's Avatar
Had the exact same problem, the release has no pressure, came back a day later and yanked extrmemly hard and it worked.... wierd
Old Sep 24, 2012 | 12:14 PM
Nismoali's Avatar
Hey does anyone know where i can purchase a lever from, my is broken. If i pull the string my hood still opens, its just really hard to. All i need is the plastic part that connects to the wire to pull it. Lmk please.
Old Jul 11, 2016 | 05:07 PM
JimG35's Avatar
I broke my hood release lever 'switch' too. Do I need to replace the whole lower driver side panel? Has anyone done a 'home made' fix?
Old Jul 11, 2016 | 10:38 PM
hurleyguys's Avatar
way to revive a dead thread
but in the exploded parts diagram. it looks like you have to buy the whole panel. most are around 180 - 200. you can prob get one for cheap in a part out or a junk yard. or you could just ghetto fab it by attaching the wire to a metal rod and just pulling it.
Old Jul 11, 2016 | 10:39 PM
hurleyguys's Avatar
oh and by the way the part number you are prob looking for is 68106-AC70D assuming you have an 04 coupe.
Old Jun 3, 2021 | 03:00 PM
ChrisG506's Avatar
It’s ok
Thanks.
you can also buy a new panel maybe the lever is just broken like mine is the dash panel is like 35$ on eBay
arora_g35
Apr 16, 2026 02:52 PM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
