clutch wear?
Old Oct 18, 2003 | 04:02 AM
nuttyprof's Avatar
clutch wear?
how do you know when your clutch on a 6MT is beginning to wear down? does the engage point get higher or lower...mean closer to the floor or furthur from the floor. anything else i should be looking out for? thanks
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Oct 18, 2003 | 03:14 PM
BobbyD's Avatar
Re: clutch wear?
Higher engagement point, away from the floor. More rpms to get the car rolling and difficulties shifting gears.
2003 G35 Sedan 6MT
14.35 @ 98.62
Old Oct 19, 2003 | 03:57 AM
ryoken's Avatar
Re: clutch wear?
And it's gone when you fully engage the pedal, and the engine revs up higher than it should and you feel the car not moving as quickly as it should.. then the rpm's will drop back down and engage (all while holding a constant throttle).
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
AL8782
Oct 3, 2015 10:26 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
Jeff T
Sep 30, 2015 02:00 PM
