Sep 20, 2006 | 12:28 PM
Before you say it, I did do a search. My question is how difficult is it to remove and reinstall the tire pressure monitors from old wheels to new wheels? I imagine the tire store will have to do it. Is it just glued in there, and is it easy to get damaged during replacement?
Reply 0
Sep 20, 2006 | 12:49 PM
Any tire shop can do it....had mine taken out of my OEM rims & put in my Milano's. The only issue is once you take them out & put them into a new set of wheels, you need to go to the dealer to have them reprogram the car so that it reads/talks to the sensors again. Don't think they can get damaged..I saw them when they were out & didn't look that delicate. What is your concern about damage all about? Don't trust the tire shop?
Reply 0
Sep 20, 2006 | 02:31 PM
As long as you use the same sensors they do not need to be reprogrammed. A 12mm socket is all that you need to remove them. & yes they can become damaged by the tire machine if they don't have a clue.
Reply 0
Sep 20, 2006 | 06:52 PM
you remove 1 bot and pull it out, no glues.
Reply 0
Sep 21, 2006 | 11:43 AM
Thanks for the replies guys. The info helps.
Reply 0
Sep 21, 2006 | 12:50 PM
Quote: As long as you use the same sensors they do not need to be reprogrammed. A 12mm socket is all that you need to remove them. & yes they can become damaged by the tire machine if they don't have a clue.
He may need to reprogram them if he upsizes and his new wheel/tire combo uses a different pressure.
Reply 0
Sep 21, 2006 | 01:51 PM
Quote: He may need to reprogram them if he upsizes and his new wheel/tire combo uses a different pressure.
Tire size does not affect the sensors. The sensors cannot be programmed to operate at a different pressure. That is pre-programmed into the BCM & Infiniti gives us no alternate program for that.
Reply 0
Sep 22, 2006 | 08:18 AM
Quote: Tire size does not affect the sensors. The sensors cannot be programmed to operate at a different pressure. That is pre-programmed into the BCM & Infiniti gives us no alternate program for that.
Yeah, that sucks. I was led to believe on this forum that you could reprogram (raise the min. pressure at which the light goes on), but when I brought my wheels to get the TPS's put in & adjust the settings, they told me it cannot be done....oh well.
Reply 0
Sep 22, 2006 | 04:15 PM
so do most people just drive around with the low pressure light on?
Reply 0
Sep 22, 2006 | 04:50 PM
no. the light doesn't come on unless you drive for a continuous 50 miles or more. essentially, you will only get the light when you are on road trips.
whenever you turn the car off, the light goes off too! and won't come on again until you go for a long drive.
I usually go weeks at a time without seeing the light!
Reply 0
Sep 23, 2006 | 12:19 PM
Quote: no. the light doesn't come on unless you drive for a continuous 50 miles or more. essentially, you will only get the light when you are on road trips.
Ok guess I can deal with that, I'm that nitty picky that I would hate to see that light and can;t do anything about it. Since I have'nt seen the light since I owned my car, my question is, does the light get accompanied by the loud buzz for about 40 seconds? It did it once on my 04 TITAN
Reply 0
