Burnt My Cat Up :/
Old Sep 21, 2006 | 08:05 PM
ttrank's Avatar
Grocery getter
Originally Posted by Sleeper43
Nope - I have 32k on my car and it was kinda abrupt after i put my mods on.
I got maybe a weeks worth of power and then my car acted a little sluggish
and started to smell like rotten eggs on occasion.
Is this a freak thing?
Does Magnaflow make a cat for the g35 sedan?
if not
Is Crawford the way to go? I know everyone has opinions but i was hoping someone could just give me the consensus
Thanks for the feedback
I had Kinetix cats for a while. They were great and a nice lower price alternatve to the Crawfords.
Old Sep 22, 2006 | 07:51 AM
SixFive's Avatar
I've heard that right after an ECU reset the car runs way rich. I can't imagine that happens in a couple days tho...
Old Sep 22, 2006 | 03:15 PM
DaveB's Avatar
Originally Posted by Jeff92se
Running rich will burn a cat up. Mods will make a car run lean (if they really do that)
Actually, I've read in the link that I posted that running lean is far more dangerous to a cat than running rich. The lean condition causes high exhaust gas temps which fatigue the cat elements.
With that said, with today's ECUs and emissions control systems, you're not going to run dangerously lean or rich. Sure, mods may throw your A/F to upper ends of the OEM ECU limitations, but it's not going to blow your motor or burn out a cat. The O2 sensors and knock sensors will keep that from happening...at least on an NA car.
Old Sep 22, 2006 | 03:17 PM
DaveB's Avatar
Yep, right after a reset, the car will run rich hence the reason the car feels boggy after a reset and why the intake noise is soft. Over the next 30 to 40 starts, the ECU will slowly dial in the right overall A/F. The default rich A/F is there to save the motor when the car is first run to compensate for atmospheric conditions.
Old Sep 23, 2006 | 10:23 AM
SixFive's Avatar
Only thing that makes me wonder is why when I had the stainless Injen on my car after a reset, my car sounded like a cobra - massive noise that disappeared after a few days of calming the ECU down. I gave up trying to figure it out and just do a reset for the TCU to tighten up the shifts and stop slipping/pausing on the 2-3 shift when at 1/2 or 3/4 throttle. The car can feel like a bucking bronco...and not because of what you're thinking.
Thebaws11
Jul 2, 2021 11:36 AM
Crisci33
Jun 29, 2017 08:31 AM
Thebaws11
Nov 30, 2016 12:54 PM
magnetism80
Jan 27, 2016 12:57 PM
NJ6MT
Oct 9, 2015 05:02 PM
