suicide doors
Old Oct 2, 2006 | 02:55 AM
timpone's Avatar
ok u got me there but then again to each his own
Old Oct 2, 2006 | 08:36 AM
mrgags's Avatar
have u guys ever seen the gullwing door conversions, those are pretty crazy, i would never do it on my g, but i've seen it on a few cars and its definately unique
Old Oct 2, 2006 | 09:44 AM
timpone's Avatar
could someone possibly photoshop them on the g or has anyone seen them
Old Oct 2, 2006 | 12:33 PM
jimmyc13's Avatar
Good luck w/ that. Photoshopping them onto a car isn't like photoshopping rims on a car....rims in a pict of a car is one-dimensional. Wouldn't putting suicide doors on a car (in open position) require picts of the G-sedan door opening in reverse....no? Or am I just thinking too hard? I think the only way you'll be able to see it is if someone has them.
Old Oct 2, 2006 | 01:22 PM
Clean G 4D's Avatar
oops... sorry guys. I skimmed through the original post and thought he meant the lambo doors. My bad...
IMO... suicide doors for the front would be more retarded than the lambo doors...
Suicide for the rear? I think its all preference, but the thought has crossed my mind. And you really dont need to find a pic on a G sedan. Any sedan with it should be good enough to give you an idea of how it will look.
Old Oct 2, 2006 | 01:26 PM
Clean G 4D's Avatar
here... this guy has suicide doors... sort of..
https://g35driver.com/forums/showthr...ht=transformer
Old Oct 2, 2006 | 01:51 PM
chinaman_87's Avatar
it doesn't fit the car.
Old Oct 2, 2006 | 02:11 PM
az1anbeethoven's Avatar
that **** is gay...dont do it
Old Oct 2, 2006 | 02:45 PM
G35_ChrisTaco's Avatar
You could only really do suicide doors on a coupe w/o massive work. The middle brace on sedans couldn't support the weight of both the rear and front doors opening at the same time. (You would have to re-enforce it quite a bit to make it structurally sound). Plus it'd look pretty retarded if you didn't suicide both rear and front doors. On top of that if you didn't suicide both rear and front doors, they most likely would hit each other when you opened them at the same time.
Most body shops that suicide doors on mini truck usually charge about 1k for each door. You weld in the new mounts, re-enforce the door and the pillar and move all the hardware. Lot of work, moreso on a car.
Old Oct 2, 2006 | 11:06 PM
timpone's Avatar
sorry i didnt specify this before but i plann on just doin the back suicide i would never do front suicide or coupe suicides i want the look of the old lincoln continental i think that its the hottest look on a sedan nd those that say that there "rice" or sumthin like that please give a reason y i hate it wen ppl just say dont do it there gay or sumthin like that
Old Oct 3, 2006 | 12:47 AM
Grumpy_G's Avatar
Its definately not rice. Rice is stickers, wings, and neon lights. Spinner is on another level, one below rice. Oh yeah, and led squirter!
It's an old school body moded trick, like shave door handle & frenched antenna, very classy when properly executed. Depending on the look you're going for. I know what you're saying about the Continental, but the Lincoln b-pillar doesn't extended to the roof. Their doors doesn't have window frame. When rolled down, it create a big open space for that clean look. Not sure if you can pull off that same effect with the G.
It's a LOT of work, but if you're putting together a show car and pulling all the stops, why not. Be the first.
Old Oct 3, 2006 | 01:15 AM
2006_G_coupe's Avatar
Id like to see suicide doors chopped on a coupe.!! Who knows,it might look good.!!
Old Oct 3, 2006 | 09:48 AM
timpone's Avatar
naa if had th coupe i would do those enzo ferrari doors or lambo doors not suicide nd ive seen suicide doors on the 300c and it looks crazy i jus want smtin thats diff and noone has it nd still loooks good
Old Oct 3, 2006 | 09:53 AM
Texasscout's Avatar
Nooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooo (pant pant) oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooo (pant pant) oooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooo (faint.....)
Old Oct 3, 2006 | 10:08 AM
  #30
UFGatorG35's Avatar
Well, um, said
