Quote:
how'd u get only 2 rear d specs?Originally Posted by jimmykce1
Since I got revised springs can I get away running the sport shocks up front and get a set of D-spec's for my rear since the spring rate is 427 vs 342??
Quote:
Yes. But I wouldn't set them past 4 clicks off full soft. Otherwise you would just be copying oem revised rear Z shocks. Stiffer spring + stiffer shock while the front stay's soft on oem shocks is not a receipe for at the limit fun. Originally Posted by jimmykce1
Unfortunately, you can't get just rear D-specs.
Didn't you just buy a revised 05 Z shock/spring setup on my350Z?
