rear bumper replacement?
Old Oct 2, 2006 | 02:56 PM
Jack06's Avatar
Does anybody has instruction to replace rear bumper? I got hit when I stopped at red light. Thanks for any input.
Old Oct 2, 2006 | 06:32 PM
soaped's Avatar
I might have missed a few simple steps, but to remove the rear bumper:
remove the trunk carpet, and styrofoam pieces.
remove the left, right, and rear liner (pop out the pins)
remove the trunk opening liner (pull carefully)
there are 4 nuts that hold the left and right tail-lights on. unbolt those and unplug the light. should wiggle right out.
the rear bumper is held on by a 3 pins (2 top covered by taillight, 1 bottom near center), and 2 bolts on the side (underneath).
should be easy once you do it once (a lot easier than the front).
Install in reverse order.
Old Oct 3, 2006 | 12:26 PM
Jack06's Avatar
Thanks soaped, that will help a lot.
Old Oct 30, 2006 | 05:39 PM
COMPNETBOBBY's Avatar
think it will be the same for an 04 coupe?
rezendvous420
May 31, 2020 01:26 PM
st33zygill
Jul 29, 2015 10:05 PM
T.Y.M1210
Jul 29, 2015 11:53 AM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
