unorthodux pulley set
The seal will depend on the install and quality of the materials. UR is a good company with good products. I think you will be fine here.
The balance is mostly in the build quality also. You can have your engine rebalanced with it on there but from what I know it's a pain and not worth it for the gains from those pulleys.
Not certain about the VQ engine but on the VG engine, they are not causing any issues. I have a UR set on my 300zx Twin Turbo and no problems whatsoever. However, many people have reported problems with Ebay pulleys.
Yes, there have been some problems with the other brands. I have not heard anything about the UR ones.
I would check around on my350z to see if anyone has had any issues on there.
thanks for the info.. i will make sure its balance and sealed right, also to balance the ur pulley the right way is this by using a special tool or just simply installed properly by an experiance tech? has anyone installed these ur pulley set and felt noticeable horsepower or had problems?
I have had the UR pulley on my Maxima VQ engine for over 35k miles. No issues. Just make sure your installer knows what he is doing.
Ref power. What I have noticed most is that there is no drag on the engine when the A/C comes on. So I guess you get something back by using the lighter pulley.
