Pinging Spark Knock Pre-Ignition
Old Oct 27, 2006 | 03:49 PM
absolutg's Avatar
workin...
thanks for the info guys... sorry i was a little lazy and should have just googled
Old Oct 27, 2006 | 04:01 PM
ttrank's Avatar
Grocery getter
It's cool. That's what we are here for.
Old Oct 27, 2006 | 06:03 PM
droppin_deuces's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
5. ttrank (only at very high rpm on hot days with Stillen stage 4)
6. trey.hutcheson (from the factory) - 32k miles, stillen airbox, ztube, mrev+, test pipes, exhaust - part throttle, heavy throttle, low rpms, WOT, cool, hot
7. Foo_G ( on acceleration and in high RPM it is really bad )
8. SHaigh (stock, discovered @6K miles, when engine is very warm, details in other thread)
9. 6MTzer (low rpm's, comes and goes, usually when the outside temp is hot.)Motordyne Plenum Spacer.
10. droppin_deuces (thanks for starting this BythaBay)
Old Oct 27, 2006 | 06:12 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
Is anyone seeing a high idle by high I mean consistently over the spec of 650 rpm.
Mine idles consistently at 700 and seldom drops rather it typically will raise to about 710 maybe 720.
Old Oct 27, 2006 | 06:29 PM
Forgot to mention...I've been experiencing the pinging intermittently at low rpms.
Old Nov 1, 2006 | 04:46 PM
BUHTSER's Avatar
Originally Posted by droppin_deuces
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
11. Buhtser( 2005 sedan did it stock K&N only, 2006 450 miles does it also)
bythabay's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
Old Nov 5, 2006 | 06:28 PM
MK G35 Sedan's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
12. MK G35 Sedan (2005 6MT Sedan, Stock with K&N panel filter, 16k miles, pinged from day 1 @ 1600 rpm, minor ping up through the rev range, much less ping when ambient temp is less than 65 deg. F - dealer 'cannot duplicate')
Old Nov 5, 2006 | 07:12 PM
Nickk6's Avatar
Originally Posted by ttrank
It basically sounds like hundreds of tiny metal ***** being poured onto a piece of tin.
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
13. Nickk6 - happens in the 2-3k rpm range on light-heavy accel., sounds like ttrank describes.
Old Nov 10, 2006 | 06:53 PM
Foo_G's Avatar
Hey BTB, I am scheduled for service on Tuesday. When I spoke to my SA he mentioned the vvt sensor briefly. This dealer that i go to is very on top of things and expect good treatment but I am confident this problem lies in the brains of this beast and I am not very hopeful that they will be able to move Nissan for the update we think is needed to address this matter.
Have you taken your car back to the tuner shop for the fix yet?
Old Nov 10, 2006 | 07:11 PM
bythabay's Avatar
No, I haven't done this yet... I'm thinking of not doing it since my sedan has pretty much stopped pinging. Well it still pings, but it does it the way all the other rev-up VQs do.. initially and then goes away for the rest of the time (computer adjustment). Yeah, before my car would ping all the time, but now it seems okay.
Old Nov 12, 2006 | 04:56 PM
Foo_G's Avatar
Good to hear it is within tolerable limits again.
Old Nov 16, 2006 | 12:30 AM
Gspott's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
14. Gspott- occassionally @ low rpm & occassionally @ high rpm, under throttle . But put in 100 octane race gas @ California Speedway & it was gone.!! What a boost in performance We need better gas here in So.Cal.
Old Dec 8, 2006 | 10:08 AM
dirrtybear's Avatar
raises all-in
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
15. dirrtybear - Started happening after 32K miles and when the temps dropped. Only happens when engine is cold. Goes away after engine is fully warmed up. Pings between shifts (clutch depressed), and when I let off the gas. Ping goes away when I step on the gas, but occasionally pings again, even when I'm on the gas.
Old Apr 14, 2019 | 08:13 AM
  #30
Joneseyo's Avatar
G35 6MT premium with sport package
Originally Posted by bythabay
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
12. Joneseyo- 07 6mt coupe pings upon take off and at low speed acceleration.
