Need Help: Removing Decal
Old Oct 29, 2006 | 05:15 PM
synaptik_1's Avatar
Search "debadge" or "debadging" -- there's tons of stuff here on it
Old Oct 29, 2006 | 05:26 PM
hai109's Avatar
Heat gun and floss...Then some goo gone for the rest of the glue...
Old Oct 29, 2006 | 05:27 PM
jameyb's Avatar
+ 1, search debadge but it's simple - 1. heat with hairdryer, 2. use dental floss to pull off emblems, 3. Goo Gone any remaining residue, 4. wash and wax.
Note - Mt. Fuji emblem has holes behind it on sedans so don't debadge unless you want to fill holes.
Old Oct 29, 2006 | 05:39 PM
Nickk6's Avatar
Don't use goo gone on your paint, you can simply heat the black stuff up and remove it, by hair blow dryer or let it sit in the sun. You can also use some good car wax and let it soak in and rub it off.
*edit* nevermind I guess I didn't reply soon enough.
Old Oct 29, 2006 | 05:41 PM
jameyb's Avatar
You are using the same stuff I used. Heat the residue and use your fingernail *VERY CAREFULLY* to remove the large chunks. Then wipe with the goo gone. It took me at least an hour to get mine all the way off.
Old Oct 29, 2006 | 06:33 PM
jameyb's Avatar
Yeah, I did but I wouldn't let it sit too long. I always get weary when putting crap on the paint.
Old Oct 29, 2006 | 06:54 PM
BuckeyeG's Avatar
try NON chunky peanut butter I used it onmine and it worked alright.
Old Oct 29, 2006 | 08:02 PM
synaptik_1's Avatar
Looks good!! What wax did you use after you were done with the debadging?
Old Oct 29, 2006 | 08:17 PM
az1anbeethoven's Avatar
much cleaner!
