OEM 19's Come in please
Originally Posted by stock sedan
Okokok..i have a 03 sedan..i also have coupe 19s but its not on yet...im thinking bout running 225/35s in the front and 235/35s in the rear, im dropped on Tein S-Techs...anyone here no the REAL answer on this setup? will it rub or not without having to roll the rear fender????
Originally Posted by ashish
Quick question about fender rolling,
does it affect the look on the exterior car (such as the fenders flaring out more), or do they just roll the metal inside the fender to shrink it more? any possible cons with fender rolling and what are normal price ranges to have the fenders rolled?
Originally Posted by vietjdmboi
what size spacers are you guys running?
Originally Posted by Viscous
I don't think anyone has tried 235 35 19"s in the rear. Mainly because those are some rubberband tires that you are planning on running. The closest thing to our stock tire diameter is 235 40 19; you'll be two sizes too small in front and one size too small in the rear. Probably won't rub but you won't know until you try it out. I'd be more inclined to get beefier tires and rolling the fenders so the ride quality won't suck ***.
Originally Posted by godmans
I run 255/35/19 at the back =)
i had a set of coupe 19s on my 06 sedan 6mt with sport package...dropped it on 350z h-techs and ran a 245/35/19 on the rears....no problems rubbing except on really big dips and hard turns......my fenders are not rolled btw.....
I'd run that over my 245 40 19 if I didn't already have them on the wheels. 255/35 19 is actually closer to stock diameter than the 245/40 setup. Which brand tires do you have and what size did you combo it with in the front?
245/35/19 front 255/35/19 rear
Micehlin PS 2 =)
my fender is rolled in for ~ 30degs
Even before the fender was rolled, i dun rub unless if i hit a big bump/ dip
Ok bring back an old thread. I am thinking about getting a set, but I am getting all fronts since I am awd. So they are 19x8. I am lowered on Tein 350z h-techs. Do you guys still think I will have problems running in the rear since is a 8 width. I think the offset is either a 30 or 33. I can get this set for really cheap. Thanks.
Do I have to run 234-40-19 on those. I cant run a 245 on all. The reason behind the 19 is because my 20 run alittle rough and also I want alittle bit lighter weight wheel. I love the look of my 20 but are roads are getting way to messed up here in Wa. Also on a side note. Jeff are you going on the Zeke run this weekend.
