OEM 19's Come in please
Old Oct 30, 2006 | 05:00 PM
03DSGCobra's Avatar
I was just at my local dealership and he said he was unsure if the 19in coupe wheels would fit on my 06 sedan. He said they have a different offset. I know there are plenty of guys in here that have them, do they rub? How big of a tire can you run in the back? What tires do you have? Post some pics!!!
Old Oct 30, 2006 | 05:05 PM
Jeff92se's Avatar
Red Card Crew
Coupe and Sedans feature different offsets. This is TRUE. But the Coupe 19s do fit on the sedan. If you use stock or a very mild drop, they won't rub the rears. IF you go lower than 1" then you need to roll the fenders or use a tad thinner tire. Rolling is much cheaper. And you will come across people that lower the car down quite a bit and let the huge camber fix the rubbing (ie.. top of tire angled in) but that's the wrong way (and expensive way in the long run, RE050s are expensive!) around the problem.
Old Oct 30, 2006 | 06:29 PM
RocketG35's Avatar
Why do I bother to DIY???
As Jeff92se said...if lowered they will rub in back w/ the stock 245/40/19 tires...supposedly you could go smaller and avoid the rubbing. I'm on Coupe springs in the rear and when I had them on, they rubbed under medium cornering.
I think they looked great though..really aggressive + you can't beat Rays quality. [these pics were taken with Z springs all around]
I have a set for sale by the way if you're interested
https://g35driver.com/forums/archived-sales/123459-fs-19-oem-coupe-wheels-w-tires.html
Old Oct 30, 2006 | 08:06 PM
conesweeper's Avatar
Lowered on Eibach Pro kits.... rears were rubbing during some dips even without any passengers or cargo in the trunk, so I had to trim the lip of the rear fenders
Old Oct 30, 2006 | 08:14 PM
RocketG35's Avatar
Whoa - all silver???
Old Oct 30, 2006 | 08:21 PM
Yessir... Brilliant silver
or do you mean the other cars??? The LX470 and S500 are white.
Old Oct 31, 2006 | 01:04 AM
RocketG35's Avatar
All our G35s are silver...but you're right...your cars are all silver too. Our two cars (G35 + Touraeg) are silver as well...next car has got to be another color.
Old Oct 31, 2006 | 03:47 AM
03DSGCobra's Avatar
If you dont lower it at all, will it rub?
Rocket do you have the revised Z springs?
Old Oct 31, 2006 | 04:13 AM
RocketG35's Avatar
I have the unrevised Z springs and shocks on the front (too rough IMO)...the back is a Coupe spring so that its slightly higher. Regardless if you run Z or Coupe in the back...it will rub with the stock tire.
I don't know if it will rub when you are at a stock height in the rear - my assumption is yes...but since the gap is a lot higher, and you probably rarely use the full suspension travel, you probably won't ever notice it.
Old Oct 31, 2006 | 05:19 AM
Klubbheads's Avatar
https://g35driver.com/forums/showthr...ight=coupe+19s
Old Oct 31, 2006 | 10:07 AM
chobble19's Avatar
morons! they always jump to their little conclusion as quickly as they can to try and shut u up...i hate that! u will get some rubbing whether its dropped or not...it wont be as bad on stock height but going over dips and snug turns u will get some minor rubbing on that inner lip maybe 1-2mm in tops nothing serious but ull notice. i am on h techs and have my fenders rolled...i am thinking of having them shaved b/c my oem 19's were sold and i think i may have a new set chrome volk gt-7's on tomorrow we'll see
Old Oct 31, 2006 | 10:25 AM
da mayor's Avatar
those 19's make a difference from the stock 18's. too bad i cant find a clean set of 19's
Old Oct 31, 2006 | 10:33 AM
chobble19's Avatar
mine were on ebay for the last 10 days and sold for 1400+shipping where were u? theyre always popping up in the classifieds....
Old Nov 4, 2006 | 04:56 AM
03DSGCobra's Avatar
I found some local, but dont know if I want to role the fenders. Should I do it guys, is anyone not happy?
Old Dec 6, 2006 | 01:38 PM
RocketG35's Avatar
I ran the Coupe spring rear on the 245/40 tire and it rubbed.
I really don't think you can get away without it rubbing unless you drop the rear width to 225 (245/40 rubs). The width is what is causing the rubbing. Dropping the height to 35 (245/35) may help some, but I think you'll still get rubbing as it will always be 245mm wide.
BTW, even those that aren't lowered get rubbing, so I don't think the negative camber helps enough.
