Will M35X 18" wheels with +40 offset fit?
Old Oct 31, 2006 | 12:18 PM
esfoad's Avatar
OK, so I see these, they look good. Will they fit my '05 G35X without spacers or rubbing issues?
Old Oct 31, 2006 | 12:25 PM
ttrank's Avatar
Grocery getter
Yeah they should fit fine.
I assume they are not larger than 8.5" wide?
Old Oct 31, 2006 | 12:31 PM
az1anbeethoven's Avatar
yeah they should fit perfect if they are +40mm offset and not like the 19" m35 sport rims with +50mm offset
Old Oct 31, 2006 | 01:13 PM
esfoad's Avatar
Here's a picture. Is this the correct wheel? The guy says 18" x 8" +40mm.
Old Oct 31, 2006 | 01:16 PM
ttrank's Avatar
Grocery getter
It sure looks like a 8" given how bulged a 245 is on it.
Old Oct 31, 2006 | 01:18 PM
yup..it should be a direct bolt on...good stuff...
Old Oct 31, 2006 | 01:27 PM
esfoad's Avatar
Thanks, I'll see if I can work it out with the guy.
Old Oct 31, 2006 | 01:44 PM
mrgags's Avatar
i've never seen those infiniti wheels, are those factory M35x wheels, they look nice
Old Oct 31, 2006 | 04:15 PM
esfoad's Avatar
I bit on them. I will go get 'em soon and let you all know.
Old Oct 31, 2006 | 04:20 PM
Jeff92se's Avatar
Red Card Crew
Um I saw the auction. They aren't factory wheels. They are enkei wheels that fit the M35x. Nice looking though. Good luck.
Old Oct 31, 2006 | 05:29 PM
mrgags's Avatar
yup i saw it on ebay, after i posted here, they look nice tho, but they looked mad tiny on the m, but they r nice, enjoy
Old Oct 31, 2006 | 07:13 PM
21ANDUP's Avatar
L.E.O. DESIGNS G35
Thumbs up
get 'emm, they look nice! I had some M45 wheels on my G35 sedan and they fitted perfect but once I installed brembo's from my friends 350z the front wheels wouldnt clear the calipers but the rear did. so, you should be fine with those wheels, good luck on your bid!
Old Oct 31, 2006 | 07:42 PM
esfoad's Avatar
Thanks all, I'm picking them up on Thursday but I won't be putting them on until the spring! However, I will do a test fit
Old Nov 1, 2006 | 12:05 AM
350.GT's Avatar
Thumbs up
wow thos look clean! good luck
Old Nov 1, 2006 | 09:22 AM
esfoad's Avatar
Thanks, yes they do. I get 'em tomorrow around Noon.
