improving sport suspension?
Old Nov 4, 2006 | 03:08 PM
chobble19's Avatar
++++++++++1 get the nismo sway bars they come with better bushings
Old Nov 4, 2006 | 06:18 PM
kenasaki's Avatar
gotcha so anything that involves suspension upgrades, they're all the same. cool.
Old Nov 5, 2006 | 11:10 AM
SFG356MT's Avatar
you really can't go wrong with any suspension upgrades. Just do your research and determine what kind of ride you want ( ie....just to lower ur G or to turn as if ur on rails) Sway bars are a good to start with but springs may be what ur looking for. Good Luck. I'm very happy with the suspension upgrades I've made.
Old Nov 13, 2006 | 02:31 AM
G35Dreamz's Avatar
does the unrevised z springs require a camber kit?
Old Nov 13, 2006 | 02:46 AM
chinaman_87's Avatar
a lot of people say no but sometimes it depends on the car. they say a one inch drop all around usually doesn't require a camber kit because it can be aligned back to specs. good luck
Old Nov 13, 2006 | 03:00 AM
absolutg's Avatar
workin...
you will not get back into OEM sedan specs with the unrevised springs but you can get close to or within OEM coupe specs. regardless, the camber isn't so off that it's a big deal as long as the cross camber difference is close to 0.
i have ~5-6k miles after the drop and no abnormal tire wear.
Old Nov 13, 2006 | 05:50 AM
jimmykce1's Avatar
I just dropped my car with 350z spring/front and coupe springs/rear. The techician got 3 of my wheels back in the range of stock settings of a sedan with sport suspension, which is the same as a coupe. The right front he only got to a -1.2 camber.
I will probably go ahead and get front adjustable camber kit.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
R350k5
Oct 1, 2015 08:41 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Jyounya
Sep 12, 2015 04:03 PM
spanky99l
Sep 7, 2015 12:46 AM
