Tire Pressure Sensor ON/OFF?
Old Nov 22, 2006 | 08:37 AM
MardiGrasMax's Avatar
Do you guys think a small air tank thing made out of PVC pipe with a schrader valve and put the sensors in side and seal it up and presurize it up to 30psi that it would trick the monitoring system?
Old Nov 22, 2006 | 09:00 AM
Coach's Avatar
I was told by the Infiniti service manager here that they temporarily disable the TPMS system for many customers
every fall when they switch them to snows, and turn it back on again during the spring tire swap.
But I also see other members like the OP reporting that their dealers insist that it can't be disabled.
Either somebody's wrong... or both are giving the right answer to different questions.
Maybe the dealers that say they can't disable it are really saying that they won't do it for free.
Old Nov 23, 2006 | 02:02 AM
bigdady1's Avatar
If you're on this site, that means that you love your G and you constantly care for it. So the TPMS is redundant. I don't care about the sensors at all. I just keep an eye out on the tires and check them ever so often. So getting on with my point... Get a screwdriver and take an hour and pull out the light bulb lighting up the warning light.
Old Dec 15, 2006 | 01:14 AM
2K6G35's Avatar
WTF, I brought my car to the dealer to refinish the 19" OEM wheels because of stains. I took it home after they refinished the wheels and found out that they stole all the TPS from my OEM wheels. Now, my tire pressure monitor is ON all the times.
Old Dec 15, 2006 | 08:58 AM
Coach's Avatar
If those are the after pictures, then you've still got TPMS sensors in your wheels.
On the other hand, if those are the after pictures they did a crappy job refinishing your wheels.
Old Dec 15, 2006 | 11:28 AM
Mod Friendly's Avatar
Originally Posted by ttrank
I have changed my wheels around a few times and they don't ever pay attention to what sensor goes on what wheel. The light just tells you one of your tires is low, not which one.
It actually does tell you which one is flat. If you have the navigation screen it will display the tires on there.
The sequence is
1. driver front
2. Passenger front
3. Passenger rear
4. Driver rear
That light is actually a good reminder of the car, it can save you on having to purchase tires that you didnt need to buy if you just paid attention and kept an eye on your tire pressure.
Old Dec 15, 2006 | 12:57 PM
jimmyc13's Avatar
I'm sure they really "stole" them and didn't "forget" to put them on. And to clarify, you sure you don't mean valve stem caps!? The picts you displayed show the TPS's installed with missing valve caps......
Old Dec 15, 2006 | 12:58 PM
jimmyc13's Avatar
Originally Posted by fzr
Hey everyone, does anyone know if the tire pressure sensor can be turned off if you install after market rims or winter rims?
I called a bunch of dealers and they said "No", they told me to put a black piece of tape on the the consol so I don't see the light, I was like wtf...
The dealer also told me if I drive in winter with stock rims,the salt may damage the sensors on the rims, and they cost around $130 CDN each.
Anyone with other than factory rims do you drive with the light on, doesn't it **** you off?
My winter setup doesn't have TPS's and no, it doesn't **** me off. It alarms me every time the light comes on, but doesn't bother me one bit.
Old Dec 15, 2006 | 04:16 PM
Buddy that big ole metal valve stem is the tire pressure sensor . you just dont have the valve cap on there lol. Assumptions are a persons quickest downfall. How stupid would it look if you went back to the dealer and accused them of stealing all your tire pressure sensors yet they have been on there the whole time
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
