Offset and tires question
Old Nov 9, 2006 | 02:23 AM
godmans's Avatar
I am wondering if there is anyone running the following or anything similar:
245 tire on a 8" rim in the front with a +30mm offset?
will this rub?
Old Nov 9, 2006 | 02:30 AM
az1anbeethoven's Avatar
what size are you gonna run?? i assume 20"?
If they are 20s, they will not rub if you don't lower it, I know someone with 20x8 with a +30mm offset on his new TL and it doesn't rub, and TL's oem offset is just a tad higher than our G's...
but I would get at least a +35mm offset and 20x8.5 with 245/35/20...good luck
Old Nov 9, 2006 | 02:33 AM
Klubbheads's Avatar
if it's not lower it won't rub untill u go over a bump or have 2 passengers in the back. If u shave/roll fenders it won't rub even if u lower it.
Old Nov 9, 2006 | 04:19 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
i had coupe 18's with a 245/40 on the rear and they didnt rub at all. The 245/45's rubbed with 2 people in the back. I was lowered an inch on Z springs.
-GP-
Old Nov 9, 2006 | 09:48 AM
darnelled's Avatar
I have 18x8 rims with +38 offset and 245-45-18 tires with no rubbing, but it gets close when under a load in the back. I think +30 will push it too far and cause rubbing.
Old Nov 9, 2006 | 03:18 PM
soaped's Avatar
will this rub?
It will rub without negative chamber.
Old Nov 9, 2006 | 03:24 PM
ttrank's Avatar
Grocery getter
It will rub on the front if you are turning and hit even a small bump. (assuming 20")
Old Nov 9, 2006 | 07:15 PM
Tshuelsman's Avatar
I have a 04 g35 sedan, looking to put 20's. Can you suggest a Rim width, Offset and tire size, to minimize rubbing
Old Nov 9, 2006 | 07:25 PM
ttrank's Avatar
Grocery getter
20x8.5 ~+40 Front and
20x9.5 ~+45 Rear is a great combo.
You can go lower offset and wider but you may need to roll your fenders. I have 20x10 +40 on my rears with rolled fenders and they clear but you could not go 1mm lower offset.
Old Nov 9, 2006 | 07:41 PM
^^Thats a great setup for the sedans...I personally like the front a little lower offset like +35~38mm but i didn't get such an aggressive drop as some other guys...
Old Nov 9, 2006 | 08:54 PM
ttrank's Avatar
Grocery getter
Yeah 35-38 on the front should be good too but it depends on your drop. I rub with +40 on the front when I have my wheels turned and hit a bump. But I also have a 1.3" front drop.
Old Nov 10, 2006 | 02:34 AM
RocketG35's Avatar
Why do I bother to DIY???
I have 20x8.5, +38, 245/35 all around....and don't rub on the front. I'm only lowered 1" on the front and 3/4" in the back though...
So, for me, a +38 worked great.
Old Nov 10, 2006 | 02:38 AM
I'm on 19x8.5 +38 with 245/35/19 in the front lowered 1.9" and dont rub.
-GP-
Old Nov 10, 2006 | 07:03 PM
G35m@'s Avatar
QUick QUestion - 18 vs 19 - anyone experinced both and can speak to issues with road noise? I drove a coupe with 19" and the road noise was worse than any exhaust drone could ever be -
Gdup35 - any issues with your set-up??
Old Nov 10, 2006 | 09:16 PM
ttrank's Avatar
Grocery getter
Road noise is more of a tire thing. It will depend on the size and the brand/model of tire.
