Axis Wheel Offset!!!!
Old Nov 15, 2006 | 02:13 PM
ORANGEBSRT's Avatar
I went to the wheel store to purchase the axis decades and there tell ing me that the offset is 40 in the rear. Is that good or bad......plus I want to lower the vehicle about 1.3 in front and 1.2 in rear.
Any recommendations for some clean 5 spoke to 10 spoke wheels that have a good offset and a nice lip.
Old Nov 15, 2006 | 02:47 PM
bbug's Avatar
40-45 offset all the way around is what you want. Since you are buying this from a shop you won't have the risk of not fitting. I would lower the car before going to the shop so that when you have the wheels installed, they know exactly what they are up against.
Old Nov 15, 2006 | 02:51 PM
ORANGEBSRT's Avatar
So a 40 offset isn't bad? I don't want the wheels to be sticking out.
Old Nov 15, 2006 | 03:17 PM
G35Papa's Avatar
Depends on the width of the rim in the rear. +40 is fine for 8" and 9" in the rear.
Old Nov 15, 2006 | 03:40 PM
ORANGEBSRT's Avatar
9.5 In The Rear
Old Nov 15, 2006 | 04:39 PM
G35Papa's Avatar
+40 should be okay with a 9.5 rear but it is cutting it a little close. A test fit should yield the true results or you could play with the tire size/width as well to make sure it tucks
Guys, please correct me if I am wrong.
Old Nov 15, 2006 | 04:44 PM
ttrank's Avatar
Grocery getter
+40 9.5" on the rear with the H&R 1.3/1.2 drop will require the fenders to be rolled.
I have +40 10" rears and they fit but a +39 would not! Yeah, they are that close...
Old Nov 15, 2006 | 05:42 PM
ORANGEBSRT's Avatar
what about a 55 offset in the rear
Old Nov 15, 2006 | 05:49 PM
az1anbeethoven's Avatar
wow...+55 is too much man...will not fit...get +45mm and it will be perfect
Old Nov 15, 2006 | 05:50 PM
ORANGEBSRT's Avatar
the guy at axis set it should fit fine
Old Nov 15, 2006 | 05:53 PM
^^hell yeah he would say that...anything to get a sale huh...he doesnt even care how ugly it's gonna look all tucked in...
Old Nov 15, 2006 | 05:54 PM
ORANGEBSRT's Avatar
so I should go for a 45 offset to look perfect
Old Nov 15, 2006 | 05:58 PM
^^thats right! good luck
Old Nov 15, 2006 | 06:49 PM
ttrank's Avatar
Grocery getter
Go for a +55 and get a 10mm spacer. That is what most of the guys who add the M split-5 wheels do.
Old Nov 15, 2006 | 06:52 PM
^^i thought the M wheels were a +50 offset and were not as wide... it's basically a 50/50 situation with spacers...some people use them, and some would never touch them...im the latter one...
