? DIY audio system?
Old Nov 17, 2006 | 08:19 PM
350.GT's Avatar
? DIY audio system?
Has any one in here DIY there own sudio system? if so what way did you run your amp. power wire? im keepin my stock unit but hookin up subs to my car and need to know what way to run it.
Thanks,
-Loc
P.S. and yes I did a search but came up short.
Old Nov 17, 2006 | 08:52 PM
ttrank's Avatar
Grocery getter
I did my own as well as a few other friends cars.
I started with my oem radio and then moved up to a Eclipse DD.
0-ga to the amp came in just below the ECU (had to pull the battery). Ran down the pass side to a distribution block in the upper passenger side of the trunk just in front of the wheel well.
Old Nov 17, 2006 | 09:30 PM
350.GT's Avatar
Hey ttrank im using a 4-ga. so theres an opening behind the batter or in that area?
Thanks,
-Loc
Old Nov 17, 2006 | 11:40 PM
ttrank's Avatar
Grocery getter
Thanks,
-Loc
Doubtful but you can still make a hole and use a gromet for the 4-ga. Just make sure you don't hit the ECU wires. It is not hard, just double check before you drill.
Old Nov 18, 2006 | 08:41 AM
killerlexus's Avatar
here a pic of the rubber gromet thats behind the battery. just unwrap the electrical tape and retape when you're done. so simple and no drilling.
Old Nov 18, 2006 | 08:19 PM
350.GT's Avatar
Thanks guys for your info. I worked on my system today and found a very easy way with no drill or take out the bat. Ill post up pics. later but if you lift up your carpet and the white one there is a hole with a plastic piece take that out and it will lead you to your weel well, take the plastic part off behind the wheel. sorry dont know what its called and if you look there is a ruber piece that is just hangin there that will lead you to your bat. area. took me 1hr. to install everything.
Thanks again for your help guys.
-Loc
Old Nov 18, 2006 | 08:34 PM
ttrank's Avatar
Grocery getter
Glad it worked out for you.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Kelvin Style006
May 23, 2016 03:47 AM
JustinMKN1
Sep 18, 2015 03:40 PM
Jon81035
Sep 16, 2015 04:58 PM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
