Ruff Wheels
Old Nov 20, 2006 | 03:13 PM
03DSGCobra's Avatar
What finish should I get for my Ivory pearl Sedan?
Old Nov 20, 2006 | 03:38 PM
Hugen35's Avatar
Trendsetter
umm... these are two differnt wheels
the wheels below are IForge...
Originally Posted by G35papa
I like these (Ruff 281)
But I am partial because I just ordered these
Old Nov 20, 2006 | 04:45 PM
liukai's Avatar
thats actually the first black sedan i've seen with the same rims i got. sweet!
Originally Posted by nate
I have pretty much the same as liukai = rims (278 in hyper black) and size (245-35-19 with 19x8.5). I use Mothers mag & aluminum polish for the lips when needed, so far works great. I also used the wheel wax to help them last a bit longer. As for weight, I weighed them with the tires when I took them off for winter and they are 55 lbs with tire in my size. The stock rims with winter tire is 48 lbs which I think is about the same as with the stock tire. So the Ruff 278 19x8.5 is about 5 lbs heavier than stock sport 5 spoke 17x7 rims (Tire Rack says my tires make up the other 2 lb of the 7lb difference).
As for the pic, it still needs to be lowered, but I'm waiting for spring on that.
<img src="https://g35driver.com/forums/attachment.php?attachmentid=52126&d=1157566147">
Old Nov 20, 2006 | 07:40 PM
G35Papa's Avatar
It depends on what look you are going for. I've just been puring over alot of pictures this past week deciding what look I want to go for. I have always liked the contrast of a gunmetal wheel contrast on IP (my last set was gunmetal...see gallery for pics). I still like the look of it but opted to change it up this time.
Check out this thread to help you see the different contrasts on IP.
https://g35driver.com/forums/picture-share/107860-ip-s.html
Thats correct...but the styles are similar. Both mesh, both with a curved spoke. I like the iForged so I chose the similar style Ruff.
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
