Bi Xenon Projection
Old May 1, 2011 | 03:55 PM
faiz23's Avatar
Originally Posted by r1forever80
^good luck with that. I'm pretty sure there is no possible way of mounting 4 acura tl projectors in a sedan headlight unless u completely do away with the oem reflector and fab up ur own mounting bracket or just mount them to the housing
This guy here has a point that should be noted. The TL projectors are huge and a PITA to fit into other housings. If you look at my retrofit in the crossfire forums link i posted earlier. You will see how much of the TL projector had to be cut to make it fit in the housing. Dual TL projectors would be an overkill and only assist in adding 3" to your E-Peen. I would go with a TL projector with ZKW lense with 55w ballast and run regular philips d2s 4300k bulbs. Keep in mind 55w will burn out 35w bulbs alot quicker, so no point wasting $$$ in bulbs when you burn them up. Kinda like buying hella expensive tires when you are running MAD negative Camber. If you want quad projectors then get find a different projector that is smaller and easier to work with.
Old May 1, 2011 | 04:05 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by ACFD835
I'm thinking dual tl projectors from retrofit with the 35 watt bulb in the headlight one so I can just run those in in stop and go traffic on I95 and a 55w bulb in the fog/high slot so I can fire it up when there is less traffic. This would probably be pricey, but if I'm going through all the effort for more light I might as well do it right! (so long as the tl fits up top)
Does anyone have the 55s...if so do you get flashed a lot?
Thanks again for your input.
I'm running 55's, and my projectors aren't even as nice as tl's.
I have yet to get flashed except when I accidentally leave my highs on.
They're not annoying at all with the low-beams. That's the beauty of projectors
Old May 1, 2011 | 10:27 PM
ACFD835's Avatar
I knew the tl projector was pretty big, do most people only mount it in the lower position?
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
doakley92
Sep 25, 2015 12:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
