Alingnment Specs for Sedan with 350z Springs
Old Nov 24, 2006 | 10:39 AM
marksg35's Avatar
I've had fairly new 350z springs on for about a month.I think their probably settled as much as their going to get...My question is should I have the alingnment shop set the car up close to 350z specs?
Old Nov 24, 2006 | 11:43 AM
jameyb's Avatar
I just had them set it as close to sedan specs as possible. You probably won't get there on the camber but you should be able to get to coupe spec.
Old Nov 24, 2006 | 12:57 PM
ttrank's Avatar
Grocery getter
Have them set it up to the sedan specs. The camber may still be ok but it will be close to the max. The toe and caster should be good.
My H&R springs are just outside oem spec for camber and they are quite a bit lower than the 350z's.
Old Nov 24, 2006 | 01:19 PM
DaveB's Avatar
Just tell them to set it to the Coupe specs. They should be able to get it within that range.
Old Nov 24, 2006 | 01:20 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you want it to look pretty on paper, get it set to coupe specs. Doesnt really matter what specs you do. The only thing different is the camber specs. coupe are -1.9 in the rear and sedans are -1.5-6.
-GP-
Old Nov 24, 2006 | 02:38 PM
marksg35's Avatar
Thanks for the help Guys!Off to the shop...
Old Nov 25, 2006 | 08:27 AM
DeatschWerks's Avatar
Put couple specs in the computer for mine and was able to get everything in the green. -.9 in the rear was the best we could get.
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
