Need Help With M45 Sport Wheels Fitting On My G
Old Nov 24, 2006 | 01:42 PM
jovo517's Avatar
Hey guys i just got the m sport wheels and it rubs in the front and dosent fit properly in the rear wat do i need to make this work please help lol
Old Nov 24, 2006 | 01:57 PM
GEE35FX's Avatar
Most guys have been running 5mm spacers and longer studs on the front to clear, and some run the same in the back just to push the wheel out a bit.
If you do a search on this site you will find lots of info about it.
Old Nov 24, 2006 | 02:00 PM
ttrank's Avatar
Grocery getter
Spacers are needed to fix your problem.
Search for the other guys who have them and ask what they did. I can't remember if they used 5mm or 10mm. I think you could use the stock studs on a 5mm spacer.
Old Nov 24, 2006 | 02:37 PM
JKB32's Avatar
depending on what size tire you are running a 5mm or 1/4 inch spacer will fix the problem in the front.
Old Nov 24, 2006 | 02:56 PM
FenixL1P's Avatar
rears shouldn't be a problem at all... just direct fit/bolt-on...
front requires spacers.... i have cheapie 3/16 inch spacers in front and they barely clear..... i left the rear as is... will be installing the full set of h&r 5mm spacers and extended studs all-around next week.
Old Nov 24, 2006 | 04:47 PM
Neal376's Avatar
ya also got them 350z springs installed right? take some pics!
yea, that spacer should solve your problem. your saying it doesnt fit right in the rear? is it tucked in too much?
Old Nov 24, 2006 | 05:04 PM
JKB32's Avatar
what kind of drop will the 350Z springs give you on the sedan?
Old Nov 24, 2006 | 05:26 PM
mark1478's Avatar
I really wanted to put m35 wheels on too..just dont wanna use spacers. They cant be good for the car. If i leased it, I probably would, but this baby is financed and dont wanna run a risk. I think they look sweet on a G..but they prob weigh a ton, not sure. Good luck and PLEASE post pics when done!
Old Nov 24, 2006 | 05:43 PM
VQ Hotness's Avatar
Damn, this sucks everyone is putting theses rims on their car now
Old Nov 24, 2006 | 05:54 PM
(>")> G35's Avatar
Don't cheap out on the 5mm spacers get 15mm spacers, those are hubcentric and you don't need to replace your OEM studs since those spacers bolt on to your OEM studs and you use the new ones on the spacer.
Glad I sold my M45 sport wheels, it wasn't worth the effort and cost to put on a set of OEM wheels. I bought them at a amazing good price and got a nice return on them, so it was still worth my time....
A similar post to thisw ith pics. https://g35driver.com/forums/showthr...=126389&page=2
Old Nov 24, 2006 | 05:58 PM
VQ Hotness's Avatar
Ive got hub-centric 5mm spacers....
Old Nov 24, 2006 | 06:31 PM
bigdady1's Avatar
I have these wheels sitting in my garage. I don't like how the 15mm stick out the wheel. It is under the fender but tooo close. 5mm definitely work but if you could wait a little longer... I found out the Ichiba is going to come out with a 10mm hubcentric spacer. I think this is going to be perfect. I put my car up on a hoist and tried the 5mm spacer... I think it' sto close to the suspension. It clears be less than a finger's width. So 10mm IMO will be the best way....
Old Nov 24, 2006 | 07:36 PM
jovo517's Avatar
yo neal wats good raquel told me u crashed ur car i drove by last night nothing rong yeah i got the springs it looks sick
Old Nov 25, 2006 | 08:49 PM
VQ Hotness's Avatar
As seen here:
Old Nov 25, 2006 | 10:13 PM
jovo517's Avatar
thanks for the information guys it helped
jsimonk
Dec 22, 2023 03:49 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
