Staggered Tires on Sedan??
Dec 6, 2006 | 10:44 AM
Is is possible to use a staggered set up such as the coupe uses on the sedan with the different width rims??
Marko
Reply 0
Dec 6, 2006 | 10:57 AM
yes.
most go with 8.5" in the front and 9.5" in the rear.
Reply 0
Dec 6, 2006 | 11:33 AM
Not recommended if you have a G35X though.
Reply 0
Dec 6, 2006 | 01:13 PM
Quote: Is is possible to use a staggered set up such as the coupe uses on the sedan with the different width rims??
Marko
Search around, lots of us have that.
I have 20x8.5 and 20x10 with 245/35 front and 275/30 rear.
Reply 0
Dec 7, 2006 | 03:10 AM
Search is your friend.
Reply 0
Dec 7, 2006 | 03:11 PM
Quote: Search is your friend.
But Cru can be your worst nightmare if you are not careful!
Reply 0
Dec 8, 2006 | 01:58 AM
Quote: But Cru can be your worst nightmare if you are not careful!
I'm your worst nightmare regardless.
Reply 0
Dec 17, 2006 | 09:00 AM
stay the same all around
Reply 0
Dec 17, 2006 | 12:02 PM
on the topic of staggered.
this is for an 03.5 sedan w/350z drop and sport suspension.
Front Wheel-Ruff 279 18x8.5 w/35mm offset Tire-245/40/18 Falken FK-452
Rear Wheel-Ruff 279 18x9.5 w/35mm offset Tire-275/40/18 Falken FK-452
I'm mainly concerned w/the offset and the size of the rear tire fitting.
Reply 0
Dec 17, 2006 | 04:38 PM
I would bet those rears are going to rub. That rim offset is too aggressive for the sedan.
Reply 0
Dec 17, 2006 | 04:39 PM
Quote: stay the same all around
Why would you want to go and do something crazy like that!?!
Reply 0
Dec 17, 2006 | 05:38 PM
Quote: Rear Wheel-Ruff 279 18x9.5 w/35mm offset Tire-275/40/18 Falken FK-452
No way. It should be more like +45mm.
Reply 0
Dec 21, 2006 | 11:15 PM
Think i could fit something like a 38mm for the front and a 40mm for the rear?
Reply 0
Dec 22, 2006 | 02:23 AM
Quote: Think i could fit something like a 38mm for the front and a 40mm for the rear?
38 in the front will work fine but 40 in the rear will stick out too much if you have a 9.5" rim it would work with an 8.5 but that wouldn't be an aggressive staggarded setup. You are better off getting a +45 in the rear
Reply 0
Dec 22, 2006 | 03:35 AM
Quote: 38 in the front will work fine but 40 in the rear will stick out too much if you have a 9.5" rim it would work with an 8.5 but that wouldn't be an aggressive staggarded setup. You are better off getting a +45 in the rear
+1.
Reply 0
