Need help with drop and wheels
Old Dec 12, 2006 | 10:02 AM
gway84's Avatar
Hey guys I just now registered today but I have been reading on here since July when I bought my sedan. Reading on here actually helped me to choose the G35. Ok now on to the question. I have an '03 silver sedan with the sport suspension. Now I want to lower it but not too much maybe with the tein h or s tech? Or 350z springs? I want to put on 18" or 19" wheels with some lower profile tires. Im mainly going for a more finished look i guess less wheel gap but i dont want to have a lot of problems dragging and what not but i already have a somewhat stiff ride so that wont matter. Please let me know what you guys think?
Old Dec 12, 2006 | 10:07 AM
gway84's Avatar
And yes i have done a search but i am just flooded with info and usually people want different things. I want to know what you guys think for my situation.
Old Dec 12, 2006 | 11:40 AM
4 Door Skyline's Avatar
OK heres an answer you can use:
Best springs to go with where you wont have to get a camber kit would be the TEIN H-Techs...and the wheels it all depends on the width of the wheel and the offset....
hope this helps a bit for you
Old Dec 12, 2006 | 01:17 PM
Garyv01's Avatar
^^^^ WOW that is a nice chart...thanks for the post
Old Dec 12, 2006 | 03:21 PM
gway84's Avatar
Hey thanks for the info!! Will oem 18" wheels from a coupe fit pretty easily?
Old Dec 12, 2006 | 03:24 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
yes the oem wheels from a coupe will fit fine on a sedan with h-techs or oem Z springs. However you'll need to change the rear tires from 245/45 to a 235/45 or a 245/40 to prevent from rubbing with passengers in the backseat.
-GP-
Old Dec 12, 2006 | 03:47 PM
gway84's Avatar
thanks, so if i do that i shouldnt have issues with rubbing?
Old Dec 12, 2006 | 09:42 PM
G35m@'s Avatar
WOW!!!! - I've been looking for this as I "had" tons of questions based on wheel widths and off-sets. You DA MAN!!! Thanks!
Old Dec 12, 2006 | 10:34 PM
It's been posted in the "sedan picture compilation" sticky for about 6 monhts now!
-GP-
Old Dec 12, 2006 | 10:49 PM
Chico's Avatar
^^^ I think it's been floating around for about 3 years now. BTW, that chart is a good starting point but it is not 100% accurate. For example, it says that a 9.5" wheel with a +45 offset will be outside the fender line, when in fact it is not. Just FYI.
Old Dec 13, 2006 | 02:01 AM
G35Papa's Avatar
^I think you're right Chico. I remember seeing that chart years ago.
Old Dec 13, 2006 | 11:10 PM
djkace77's Avatar
IF i got the H-Tech springs and if you have the sport tuned suspension, would it be a good idea to get new shocks or can i reuse the stock ones?
03 G35 sedan
jsimonk
Dec 22, 2023 03:49 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
