Problem with the Center console Lights
Old Dec 15, 2006 | 10:34 AM
35bills's Avatar
Your head lights are "on" when you start up the car correct? Take them off of "Auto" mode.
It sounds like the dimmer switch is not working for your dash.
My dash as well looks like yours upon initial startup-no exterior lights on.
Old Dec 15, 2006 | 11:11 AM
Floyds_racing's Avatar
I will try that but I have gone thru on off parking and suto modes already once!
Old Dec 17, 2006 | 09:35 AM
Lastnight around 11pm I decided to go grap a bite to eat and one the way home I got pulled over. well come to find out my taillights are not working either. the brake lights work but not the tail lights? is it possible to wire and by pass the roller ball? I think that my whole problem!
Old Dec 23, 2006 | 06:13 AM
Tonys-G's Avatar
there is a fuse box next to the battery, there is a fuse there that may be the problem, I had a similar issue where everything on the center console was out except the last setting that was on for the air, nothing else would work
it was a fuse in the box next to the battery check that, once I changed it everything was fine
Old Dec 23, 2006 | 10:41 AM
the fuse was bad but so is the dimmer switch
Old Dec 23, 2006 | 10:58 AM
Neal376's Avatar
i've seen this problem one too many times. have you changed any bulbs recentely?
did that reverse direction thing require any additional wiring?
Old Dec 23, 2006 | 11:06 AM
NO i havent and just switched two wires! nothing additional!
Old May 4, 2009 | 12:56 PM
acemallone's Avatar
I'm having the same problem! My heater and stereo lights are not working. and my clock light is off too! I checked all my fuses, except the one by the battery. My tail lights works still.... I remember that one time I was going for a ride, I turned on the lights and my centre console lights took a few seconds to come on? Any other things I could try? My buttons all still work for the stereo and heater, just no lights!!
Old May 4, 2009 | 01:02 PM
ShanesG's Avatar
hahaha so am I, i can't believe you found this thread i couldn't find shiit on this problem.
Old May 4, 2009 | 02:54 PM
acemallone's Avatar
Lets see who can find the problem, what have you tried so far?
Old May 4, 2009 | 03:04 PM
ShanesG's Avatar
basically took everything apart behind the battery, where that fuse box is, since thats where the fuse is located for the taillights and console lights. checked all the wires and re wrapped them since i have a wire tuck. Put everything back and everything worked fine for about 50 miles then the fuse blew again. Im gonna swap out my dimmer, even though that maynot be the problem but i donno what else to try. Everything is grounded and no wires are expose. I have no idea what else to look for.
Old May 4, 2009 | 09:38 PM
acemallone's Avatar
Which fuse is it? I looked through all of them and I can't seem to find a blown one! Also, my marker (side lights) are not working.
P.S. My tail lights don't work either!!!!
Old May 6, 2009 | 08:22 PM
FlSHRFun's Avatar
Bump! Same problem after installing LEDs. My center console lights, clock, and taillights won't light.
Please, help!
Old May 6, 2009 | 08:40 PM
G SEDAN's Avatar
my radio/ac controls wont work and my AC is stuck on AUTO, set at my last temperature setting of 73 degrees whetn it still worked. I can stil control my radio through the steering wheel controls.........cannot control chit from the center console!! HELP!
Old May 7, 2009 | 01:19 AM
  #30
FlSHRFun's Avatar
law, jk fixed it.
