HIDS & fog bulbs
Old Dec 18, 2006 | 12:54 AM
blownvert's Avatar
HIDS & fog bulbs
So I guess I just got my 2004 g35x sedan and it comes with hids. Dont hids come factory on every infiniti? How do I change those fog bulbs to match my hids, what color k is my factory hids? Is it possible to get them brighter or are they bright enough?
Old Dec 18, 2006 | 12:59 AM
abcquackyxyz's Avatar
factory hid temp is 4.3k you can get a bluer color which are phillips ultinons 6k but with higher k in hid the luminens drops so it isnt as bright. for fogs get silverstars or piaa super whites they should be close to the 4.3k
Old Dec 18, 2006 | 01:00 AM
Mmagic76's Avatar
Early 03 G's had HID's as an option. Changing the fog lamp bulbs requires opening the inner fender to access the bulb. Factory HIDS are around 4300k and are as bright as they will come.
Old Dec 18, 2006 | 02:01 AM
ttrank's Avatar
Grocery getter
Piaa makes an H4 bulb that is close in color to the oem HIDs. I would start there. Look over in the lighting section for more info.
Old Dec 18, 2006 | 08:57 AM
blownvert's Avatar
So do i have to open the fender to get to the headlight in a 04? How hard is this? I asked a ebay seller about bulbs and he responded with this
You will need 9003 (aka H4) HID Conversion kit to convert your fog light into HID in order to match the HID low beam.
We do carry the H4 HID Conversion kit in stock for 169.99 dollars a set plus S&H.
The H4 HID Kit includes two JDM H4 HID Bulbs similar to the D2S or D2R bulbs you have seen in this auction plus two Osram powered HID Ballasts.
If you are interested, please let us know and we will send you the invoice to check them out. If you want to get the low beam HID bulbs upgraded too, we also have special bundle deal.
Old Dec 18, 2006 | 10:49 AM
Andyl's Avatar
silverstars are the way togo for the fogs they are real close when you hit the fogs!
Old Dec 18, 2006 | 10:58 AM
cato's Avatar
SouthernComfort Moderator
1+ on the silverstars.
Old Dec 18, 2006 | 11:52 AM
blownvert's Avatar
so silverstars the same as the piaa xtreme whites h4? Those are like $50.
Old Dec 18, 2006 | 11:56 AM
killerlexus's Avatar
why not get yellow bulbs for the fogs.. looks nicer with yellow fogs i think. plus winter is here. yellow lights will help alot in driving when it snows.
Old Dec 18, 2006 | 12:23 PM
blownvert's Avatar
i want all white to match because i will always have them on with the headlights.
Old Dec 18, 2006 | 12:43 PM
jimmyc13's Avatar
Do you have yellow fogs? Any picts?
Old Dec 18, 2006 | 02:47 PM
ORANGEBSRT's Avatar
i ordered the yellow fog bulbs today...when I put them in I'll take some pics hopefully by friday or saturday
Old Dec 18, 2006 | 04:02 PM
blownvert's Avatar
do people get fog hid's? to install new fog bulbs you have to go from under the car?
Old Dec 18, 2006 | 04:04 PM
ORANGEBSRT's Avatar
yeah, but personally over here in atlanta, with the fog and dark back roads, yellow is a better investment.
Old Dec 18, 2006 | 05:15 PM
jimmyc13's Avatar
Which ones did you go with & where did you order them from?
