4.1 final drive 0-60 times?
Old Dec 28, 2006 | 10:32 AM
bert039's Avatar
What are your thoughts on a 3.7 FD upgrade? I believe the new 2007 sedan has a 3.69 (3.7) FD.
Old Dec 28, 2006 | 10:46 AM
jtesensky's Avatar
I have the 3.91's in my 5AT Coupe & love them. I haven't done any 0-60 runs but city driving is much better. The tranny will act a bit weird with a 1/2 open throttle gear shift but the luanch is greatly increased. At WOT the car will literally jump off the line, it totally looses the lag that it had with the stock 3.36's.
Old Dec 28, 2006 | 10:55 AM
bert039's Avatar
What do you mean "act weird"? Are you talking about when you're driving in "D" or when you're shifting yourself?
Old Dec 28, 2006 | 10:56 AM
GEE35FX's Avatar
Originally Posted by vodkarocket
I upgraded to the 3.5FD from my 3.3, and it is one of my favorite mods- the 3.9 seems a bit much for an automatic at least. It does however make driving pleasure a bit nicer since you're closer to the power zone in each gear, and you get ~8% more torque throughout the rev range...
I'm putting gears on my next car for sure.
That would be a great change instead of going to the 3.9:1, it would be a definite improvement but not drastic. All of the 1st gen automatic G35 RWD sedans and coupes came with the 3.357:1 final ratios, so a switch to the 3.538:1 gearset that is in the manual transmission models or the X models would be a nice mod.
Old Dec 28, 2006 | 11:00 AM
jtesensky's Avatar
It happens when I'm in "D", manumatic it doesn't happen at all. When I'm cruising and come off the throttle a bit, kinda like when getting on the freeway, and hit a shift point it almost feels like it's slipping. I have felt this before with the stock set up but not as pronounced. I'm not really worried about it. It doesn't happen that frequently.
Old Dec 28, 2006 | 11:01 AM
jtesensky's Avatar
You guys know that you'll lose the cruise control when you if you do this right?
Old Dec 28, 2006 | 02:45 PM
TheTrance's Avatar
jtesensky how much faster does your car feel like? any significant change?
Old Dec 28, 2006 | 03:28 PM
jtesensky's Avatar
Yeah, especially off the line. It's great for city driving. I would go on with some stories but I know it's not looked upon very highly here (street racing, that is)
Old Dec 28, 2006 | 07:52 PM
bert039's Avatar
no no! please tell , I really want to pick this up now. I just need to get hyped up about this purchase again LOL
Old Dec 28, 2006 | 09:07 PM
godmans's Avatar
Originally Posted by DaveB
That's not necessarily true. Deeper gears do not necessarily mean quicker ETs. If that was the case, then big block drag cars wouldn't be using 2-speed Powerglides and running 6s. Choosing the right gear depends on a lot of factors including:
1) Powerband
2) Tire height
3) Transmission gearing
4) Engine torque
It is quite possible to overgear a car and a 3.9 gear would do just that. Basically what will happen is the G35 will go too quickly through 1st and 2nd to give adequate acceleration. As for the 3.5 gear, I've tried it. I didn't have 3.5 gear in the diff, but I was running 23.5" drag radials which took my gearing from the stock 3.31 to a 3.55. On the same day, same track, the car WAS SLOWER with the 3.55 ratio. On average, it was .1 seconds and 2mph slower which was thanks in part to the early shift into 4th a few hundred feet short of the finish line. When the car his 4th, it just layed over. With the 26.2" stock height 17s, I am able to hold 3rd right until the finish or approximately 101mph.
Very detailed explanations and a good example of what I was trying to illustrate.
Old Jan 6, 2007 | 09:45 PM
rlwjr1's Avatar
What was your 60' time on the 23.5" tire vs. the 26.2" tire? What was the weather like on the two runs?
Old Jan 6, 2007 | 10:46 PM
DaveB's Avatar
I pulled 2.15-2.18s 60 foots on the 26.2" tires and 2.15-2.18 60 foots on the 23.5" tires. The density altitude was in the 1800' range (lower 70s, slightly humid, 900' elevation). All runs were on the same day. The car was actually hotter when running on the OEM wheels. Not that it makes a difference though because my car runs no quicker on a cold motor.
Muski_G
Dec 1, 2023 11:11 AM
RedBaronK
Jul 27, 2015 06:25 PM
tiguy99
Jul 26, 2015 01:39 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
Ninjay16
Jul 20, 2015 01:21 AM
