100 Octane
Old Dec 20, 2006 | 06:39 PM
Jeff92se's Avatar
Red Card Crew
If any of this gas has lead in it to up the octane rating, I'd be carefull. Your car might run okay, but the lead will tend to foul the cat. You have 3 so............
Old Dec 20, 2006 | 07:12 PM
falconey's Avatar
Originally Posted by sammyG350gt
dont kill me... but what about the "octane boosts" sold everywhere? I'm never tried the stuff but wouldnt it have the same effects as useing a higher octane fuel? besides knowing the exact mixture are there any different advantages to actually finding a high octane fuel at a far off distant gas station?
Those octane boosts are crap. They use fuzzy math. I forget the exact formula but I think it's really only raising the octane by a tenth(.1) octane gain as opposed to a full point. Now the I have had some good results with fuel system cleaners in previous vehicles.
Old Dec 21, 2006 | 04:11 AM
skeleton_cru's Avatar
Sedan
Originally Posted by rijen1013
take the woodside exit torwards el camino go down about 2 miles its the 76 on your left!!!!!
OK.
Old Dec 21, 2006 | 09:06 AM
G35_TX's Avatar
Originally Posted by DaveB
110 octane is most likely leaded. Pretty much any race fuel over 104 octane has lead in it to boost octane levels.
This is a case of too much of a good thing. Octane is a rating of the fuels resistance to burn. The higher the octane, the harder it is to burn. Without a super high compression, boost, etc, 100+ octane is overkill and chances are the car will make less power.
Per them it wasn't leaded. It was a new unleaded base of racefuel that was safe for cars.
dunno if that was 100% true, but thats what I been told.
Old Dec 30, 2006 | 07:36 PM
G35inSD's Avatar
Originally Posted by gary c
We'll never see that kinda gas in Ca. we're lucky to have 91 proof....haha
Racing gas is available at some stations but it's super hi-buck and not
worth running in my G. We haven't seen 100 octane since the days of
Chevron Custom Supreme........that's all I ever ran. It had so much led
content it would turn the inside of your exhaust tips a light gray color.
A new "VP Racing" Gas station just opened up next to my work in San Diego and they have 100 Octane at the pump. $6.99 a gallon but at least its available!
Old Dec 30, 2006 | 10:03 PM
ajayjuneja's Avatar
Originally Posted by skeleton_cru
Where???
The 76 on woodside road, near alameda de las pulgas.
Old Dec 31, 2006 | 07:54 PM
04NismoV35's Avatar
Originally Posted by G35inSD
$6.99 a gallon
Old Jan 1, 2007 | 01:42 PM
DaveB's Avatar
Damn, I can get 100 octane for $4.50.
Old Jan 1, 2007 | 02:19 PM
Seahawk's Avatar
Just FYI, if you car isn't tuned to use the higher octane fuel, you'll find the HP actually goes down slightly... (Contrary to popular belief, higher octane means less power, but a much more controlled burn rate).
You'll need to tune the ignition to increase and use tighter timing tables in order to gain an advantage -- tuning to have each power stroke hit on the leading edge ("sweet spot") of that controlled burn envelope will gain more effeciency so that you capture more power from the combustion even though the combustion itself may be a bit less powerful.
Keep in mind that you have to tune the timing tight to gain much that that you'd have to retune before putting the lower "premium" fuel (91-93 octane) back in or you'll be risking detonation and/or pinging which can start to cause damage real fast.
Overall, unless you can tune to take advantage of the higher octane fuel, you 'll see no difference in the best case, and possibly a slight decrease in power (though likely not noticable). Paying the extra $2.50-$4 per gallon isn't worth it
BTW - I do tune for my drag car with HP Tuners -- are there any similar packages for the 07 G? (Timing, A/F tables, etc)?
(Sorry for the rambling... It's new years and I'm not quite sober )
Old Jan 1, 2007 | 07:31 PM
04NismoV35's Avatar
I've never even seen 100 octane available anywhere by me in NY
Old Jan 1, 2007 | 08:23 PM
molidor01's Avatar
Where at in San Diego?
Old Jan 1, 2007 | 08:51 PM
dreamweaver's Avatar
yea our NY state gas sux....
Old Jan 1, 2007 | 09:05 PM
cavu's Avatar
The blue colored stuff sounds like 100 Low Lead for piston airplanes. The blue color is used to tell that it's the right stuff on pre-flight.
Cavu
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
the93owner
Sep 28, 2015 10:37 PM
awalle01
Sep 28, 2015 12:36 AM
bigmike
Sep 17, 2015 01:58 PM
