BBK Installed
Old Dec 31, 2006 | 12:03 AM
DaveB's Avatar
Originally Posted by 5150DS
Rubber flexes, stainless doesn't
Bingo. The line doesn't expand therefore the pedal has better feel. It does nothing for performance unless you consider a mod that improves driver feel to be performance enhancing.
Old Dec 31, 2006 | 12:23 AM
sjc1789's Avatar
Florida G35 Club
time for nice set of rims!!
Old Dec 31, 2006 | 12:38 AM
aszatk01's Avatar
nice, i'm running the same rotors. look nice but i honestly dont see any better stopping power....you really need some bigger calipers for that i guess.
Old Dec 31, 2006 | 01:20 AM
SFG356MT's Avatar
Looking good!
Old Dec 31, 2006 | 01:24 AM
ttrank's Avatar
Grocery getter
Very nice!
I have their 4-pot front BBK and oem caliper rear kit. Great product!
Old Dec 31, 2006 | 09:02 AM
GGRJR's Avatar
Stainless do not flex so they will give faster response and better feel. I had them on my SE-R and it made a huge difference, I will be adding them in the spring when I paint the calipers. Of course now that I have the rotors, I may just ad the 4 piston calipers, instead
Old Dec 31, 2006 | 11:56 AM
ttrank's Avatar
Grocery getter
You can't just add the 4-pot calipers, I'm pretty sure they use a different rotor. The oem calier ones are not as thick.
Yes, the lines help a lot too. A must for any car IMO.
Old Dec 31, 2006 | 11:57 AM
ttrank's Avatar
Grocery getter
Looks nice; I think Cru has the same BBK.
Yeah Cru has the on the F&R.
It's a great kit for the money.
Old Dec 31, 2006 | 11:58 AM
ttrank's Avatar
Grocery getter
Originally Posted by EQUATE
Isent that around the sAme price for a set of oem Brembos of a Z or G ?
If you can find a used oem Brembo kit for that kind of price, jump on it. Most of them go for ~$1,700. I was going to get a set but ended up getting my RB kits new with lines and all for about that price.
Old Dec 31, 2006 | 01:37 PM
godmans's Avatar
1)
I do perfectly agree on this; it just adds to the braking feel since you are putting same amount of fluid to each caliper with the same amount of braking force at the end.
2)
Bigger rotors won't help for braking power; even though it does give a larger moment arm since your caliper is now extended outward......(just imagine you are now trying to stop a flywheel with more rotational mass and larger moment arm). Yet, most of us get the kit for better resistance against fade since it has larger surface area for venting.
On true BBK with multiple brake pots, it increases braking performance by equally distributing the brake force on the brake pad when compared to a single pot oem design
Overall, I love my kit =)
Old Dec 31, 2006 | 01:41 PM
GGRJR's Avatar
According to the Racing brake forum, the same rotors are used for both the OE BBK. and 4 piston caliper kits. So it should be a bolt on.
Old Dec 31, 2006 | 01:46 PM
jared2027's Avatar
Cool thanks for the info.
Old Dec 31, 2006 | 04:00 PM
ttrank's Avatar
Grocery getter
I guess it's true for the fronts. I wish that were true for the rears. I know for a fact they won't work because I tried to upgrade to their 2-pot or 4-pot rear calipers and they said nope!
I found the forum where they say you can upgrade the fronts to the 4-pot. I wonder why my rotors that came with my 4-pot kit do not look the same as yours.
Old Dec 31, 2006 | 04:16 PM
GGRJR's Avatar
Do you have one or two piece rotors? Mine are the one piece. That sucks that the rear won't work.
Old Dec 31, 2006 | 04:32 PM
  #30
ttrank's Avatar
Grocery getter
Mine are the two pc. That forum on the RB site said the 4-pots work with the 2-pc rotors. Sounds like conflicting info.
