6MT 6 to 5 downshift problem
Old Jan 5, 2007 | 10:18 PM
RuralOC_G's Avatar
2005 G35 Sedan with 6MT and 20,000 miles. Before it is fully warmed up ( 5+ miles in 45 degree F weather ) I sometimes have a problem with the 6 to 5 downshift grinding. It is like the synchro is not even there. There is no resistance to moving the lever from 6 to 5, it just goes right in but grinds. Has anyone else had this downshift problem? Has anyone experimented with other transmission fluids? I know on one previous manual transmission car Red Line MTL made a big improvement in the way shifts occurred.
Old Jan 5, 2007 | 10:25 PM
robr's Avatar
does it ever grind from 4->5? probably is a synchro issue, at least you're under warranty.
Old Jan 5, 2007 | 10:26 PM
g-adabout's Avatar
my 05 does this also only 1 time a day, and only on the first downshift when cold. I thought it was me not putting the clutch completely in or something, but I've tried everything.
What I found that works is that if I hold off on 6th till its warm it wont happen...
anyone else?
Old Jan 6, 2007 | 01:18 AM
RuralOC_G's Avatar
The other thing that I noticed is that it happens more at 40mph or so than at 50+mph. I wanted to check on here because I read about other synchro problems, but not from downshifts and only when cool to cold. My problem started with the first downshift, but now it happens more frequently.
Old Jan 7, 2007 | 06:30 PM
Ken_G35's Avatar
Thumbs down
I have an '05 sedan and I started getting the cold grind going from 6th to 5th. I now have the cold weather whistle coming from the tranny for the first 10 minutes of driving. New tranny in my future? I have exactly 21K miles.
Old Jan 7, 2007 | 09:23 PM
Klubbheads's Avatar
mine used to do it from 4-5 at low rpms. finally when i blew my 3rd gear they replaced the tranny and its very smooth now.
Old Jan 7, 2007 | 11:59 PM
VQ Hotness's Avatar
3rd-6th grinds for me, But only when you dont let the rpms drop more then 500 rpms its weird.
New Trans going in Later this month
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Eomfd
Aug 29, 2015 12:42 AM
derres
Aug 28, 2015 03:27 PM
bdnbfrank
Aug 17, 2015 02:09 PM
NemesisGee
Aug 11, 2015 07:10 PM
