whats the difference between g35 and g35X
Old Jan 7, 2007 | 08:42 PM
skip2mylou2316's Avatar
can somone please tell me the difference between the 2?
Old Jan 7, 2007 | 08:46 PM
5150DS's Avatar
X is all wheel drive and regular g is rear wheel drive.
Old Jan 7, 2007 | 09:20 PM
ttrank's Avatar
Grocery getter
+1
There are a few other small differences but the AWD vs. RWD is the big one.
Old Jan 7, 2007 | 10:06 PM
KrazyEd's Avatar
If I could do it all over again I woulld get the regular g35. I love how my X handles in the snow but the past couple of years we havent gotten too much snow. The aftermarket is better for the RWD sedan.
Old Jan 8, 2007 | 06:46 AM
jimmykce1's Avatar
Also the G35X weighs more than the RWD G35. Also you cannot get a sports and aero package on the G35x.
Old Jan 8, 2007 | 11:16 AM
riveraben's Avatar
G35x is Faster then G35 in Wet AND Dry Conditions
R&T Magazine had a sidebar comparing the RWD G35 vs. G35x in it's March 2006 issue. It proved any additional weight in the G35x is offset by better handling in both wet and dry conditions. Below is the part of the article describing the advantages of the ATTESA E-TS (Advanced Total Traction Engineering System for All Electronic Torque Split) all-wheel-drive system in the G35x.
Road & Track, March 2006, Rear Drive vs. All-Wheel Drive: That Is the Question:
For fun, we brought a rear-drive Infiniti G35 to our autocross and compared it with its all-wheel-drive G35x brother, in both wet and dry conditions with VDC yaw control switched off. We assumed the rear-driver would be quicker in the dry, given its ability to hang out its tail and help the driver tighten his line. But in the wet, we were confident the all-wheel-driver would have a tremendous advantage, hooking up better out of turns. Here's what we learned:
Well, we were wrong on one front, right on the other. Based on group average times on the dry autocross, the awd G35x proved itself faster, surprising us with its rear-biased manners and lapping nearly a second (0.9 sec.) quicker than the rear-drive G35. In the wet the G35x fared even better, 1.3 sec. quicker than the rear-drive G35.
Credit goes to the electronically controlled awd system, which maintains a rear-drive bias while endowing the car with improved stability. Don't get us wrong, the G35x still liked to hang its tail out, but the driver didn't need to be quite so careful with the throttle to keep the car's back end in check. In the rear-drive G35, the driver had to be far less aggressive with the throttle (and quicker with corrections) to post respectable times. Wet or dry, the awd G35x was far easier to drive quickly.
The G35x's center diff is responsible. From 0 to 10 mph, its electromagnetic wet clutch splits the torque 25 percent front/75 percent rear for good grip off the line; thereafter, the car is 100-percent rear drive until rear-wheel slip is sensed. Then, the diff can send as much as 50 percent of the power forward. Although other awd systems will produce different results, the G35x proves that all-wheel drive, properly applied, can give you the best of both worlds. — Andrew Bornhop
Sepsis
Feb 12, 2020 02:05 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
