350z Springs and what the color dots mean....
Old Jan 7, 2007 | 11:04 PM
accordhybrd's Avatar
I just bought some 03 350z springs for my 06 sedan. I searched and got conflicting answers on which color dots go where. My springs have these dots:
1 Pink dot
2 Red dots and 1 White dot
Which are the front and the rear?
Thank you,
Accordhybrd
Old Jan 7, 2007 | 11:08 PM
jameyb's Avatar
1 pink dot = front.
2 red one white dot = rear.
By the way, the 2 red, one white dot means you have unrevised springs. The rears also can be identified by their larger diameter.
Old Jan 7, 2007 | 11:11 PM
G35Dreamz's Avatar
You got the unrevised springs. Pink dot is for the front, rubber sleeves go on bottom when you install the springs. 1 white 2 red is the rear. I just installed the rear springs yesterday.
Old Jan 7, 2007 | 11:12 PM
Just want to make sure I want the unrevised springs correct?
Old Jan 7, 2007 | 11:16 PM
G SEDAN's Avatar
06 sedan.....do you have sport package?...i think you need REVISED........
Old Jan 7, 2007 | 11:17 PM
Yes I have the sport package
06 sedan
6 spd
Old Jan 8, 2007 | 06:44 AM
jimmykce1's Avatar
You do not want revised since the spring rate in the rear is higher than the OEM sport G35 spirngs. The revised are 427 were as the unrevised is 342, I believe. If you install revised springs you will need to replace your OEM sport shocks too.
Old Jan 8, 2007 | 11:44 AM
townsley's Avatar
What's the difference in the spring rates between the front and rear revised springs?
I naively assumed that all the springs were the same size/same rate, so didn't even
pay attention to the dots... :-(
Old Jan 8, 2007 | 12:17 PM
jameyb's Avatar
Front 314 rear 427 for revised. Don't worry. You could not have installed them incorrectly. Rear springs won't fit on the front struts and front springs wont fit in rear (they are very different).
If you installed them and everything fit you should be ok. If you put the revised springs on and kept the stock shocks you may wear your rear shocks quicker than usual because they are not properly setup for the higher spring rate. If so, that is just an excuse to buy some D-Specs.
Old Jan 8, 2007 | 03:54 PM
On the front springs I have rubber caps on both the top and bottom of the spring. Does it matter which end it up. One end has a grey rubber cap and the other end has a black cap on it.
Old Jan 8, 2007 | 03:59 PM
G35Dreamz's Avatar
hm i didn't even see the black rubber on the other side. Grey rubber side down?
Old Jan 8, 2007 | 06:15 PM
perry05G35's Avatar
I just had the 350z G35 coupe springs installed. there is no black rubber on them. and as mentioned you will need to replace your struts with the revised springs even on a G35 with sports package. Revised only applies to the rear 350Z springs (427) the front springs have the same spring rate regardless of model year.
Old Jan 9, 2007 | 08:48 PM
perry05G35's Avatar
Originally Posted by S.E.
Thats what I wanted to hear. I have the revised z springs, but i'm only using the fronts in conjunction with coupe springs in the rear, so I should be good, yeah?
Yep revised stands for NISSAN improved the rear spring rate on the 350z and G35coupe since the 03 thru 04 were too bouncy for most owners...
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
linedr89
Aug 17, 2015 05:11 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
Duriisimo
Jul 31, 2015 02:21 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
