gas mpg
Old Jan 9, 2007 | 08:07 PM
toymachine2009's Avatar
gas mpg
what are some tips to not having to go fill your tank up every 3 days i go down to about like half a tank every 3 to 4 days thats costing me too much what are some tips so i can get better mpg
Old Jan 9, 2007 | 08:21 PM
Mmagic76's Avatar
Keep tires properly inflated, don't mash the throttle, drive on the freeway if possible, go easy when the motor is cold (drinks more gas), keep your engine properly matained (filters, oil, etc), if your parked idling for more than 30 secs, turn ur motor off.
Old Jan 9, 2007 | 08:49 PM
DieselX's Avatar
I heard having VDC off helps... don't know if you can handle the car though without it
Old Jan 9, 2007 | 10:04 PM
GeeWillikers's Avatar
Walking The Fine Line...
You didn't say what your mileage is. You say you get gas every three to four days, but if you're driving 400 miles, that's fantastic. Know whatta mean?
Old Jan 9, 2007 | 10:12 PM
i get bout 115 miles for half a tank.. and what does vdc off do and why wouldnt i be able to handle it?
Old Jan 9, 2007 | 10:27 PM
RetAF's Avatar
Assume from your reply that you still do not know what your gas mileage really is. Be helpful if you figured it out-not just guessed. Is your tank bone dry at 230 miles? That`s what I get from your comment.
Old Jan 9, 2007 | 10:28 PM
ttrank's Avatar
Grocery getter
115 miles on 1/2 a tank!?! I get better mpg than that. I still get 270-300 per tank with a TT kit. 260 if I drive all city.
Old Jan 9, 2007 | 10:43 PM
I have not let fully run down the tank i fill it up when its half empty and by the time its half empty its like 115 miles between 120's and then i go and reset the mileage again when i reset it...
Old Jan 9, 2007 | 10:45 PM
VQ Hotness's Avatar
VDC = Very Decisive Cornering. So turn it off and floor it around a corner and the car Corrects it self fixing your mistakes. So basically it wont let you lose control.
Old Jan 9, 2007 | 11:00 PM
RetAF's Avatar
And when you fill it, does it hold 10 gallons? That`s half a tank, and works out to 11-12 mpg. Sucks!
Old Jan 10, 2007 | 12:03 AM
do you all drive with vdc off or on?
Old Jan 10, 2007 | 12:09 AM
gramdacious's Avatar
I like it off if I'm gonna drive a little more aggresive.
Old Jan 10, 2007 | 09:47 AM
VDC = on.
If you don't know what it does, please leave it on. Chances are you need it. Just ask any one of the bumbling fools who disabled it and then launched their G into the nearest immovable object.
Old Jan 10, 2007 | 09:55 AM
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by GeeWillikers
VDC = on.
+1. There have been a number of members here that have turned off their VDC and learned a lesson the hard way.
Old Jan 10, 2007 | 10:03 AM
Bigd2k6's Avatar
i drive slower most of the time. i only really get on it at on ramps. i also coast at most stoplights, exit ramps and steeper hills so that's an extra 30 seconds or so of idling and the car's coasting at about 40-50 mph. my work is about 6 miles away (12 total, 6 days a week) and a couple of errands here and there. with that, 1 tank lasts me about 2 weeks and that averages out to about 340 miles per tank. road trips i can get about 425 doing 60+.
