How to reset ECU?
Old Jan 11, 2007 | 05:00 AM
03DSGCobra's Avatar
How to reset ECU?
Besides disconnecting the battery,what is the other way to reset the computer? THe gas pedal method, anyone have a link?
Old Jan 11, 2007 | 05:13 AM
BSOMTHIN's Avatar
google!
Old Jan 11, 2007 | 07:37 AM
cato's Avatar
SouthernComfort Moderator
https://g35driver.com/forums/engine-drivetrain-forced-induction/6526-easy-ecu-resetting.html
Old Jan 11, 2007 | 11:58 AM
ttrank's Avatar
Grocery getter
Works like a charm. I have done it many, many times.
Old Jan 11, 2007 | 01:16 PM
fastGkid's Avatar
now what does this resetting actually do?
Old Jan 11, 2007 | 02:53 PM
cato's Avatar
Resets the ECU to fresh agressive mode, throws the granny out the window!
Old Jan 11, 2007 | 03:10 PM
ttrank's Avatar
Grocery getter
It clears out any codes, clears out the driving habit memory, stuff like that.
Old Jan 11, 2007 | 04:12 PM
03DSGCobra's Avatar
Thanks guys, my buddy at work bought the K&N Typhon Intake and is now having a rough idle, so hopefully this does the trick. He has a coupe does that matter for reseting the ECU?
Old Jan 11, 2007 | 10:48 PM
RUS's Avatar
RUS
just reseted mine... Drove around... seemed kinda more torqueeee or maybe i am just triping =)
Old Jan 12, 2007 | 11:37 AM
RPL's Avatar
RPL
Isn't the ECU constantly changing anyways?
Old Jan 12, 2007 | 11:58 AM
cato's Avatar
Yeah, once you reset it, it will start learning your granny ways all over again. Drive it like it was stolen and you will not have this problem in the future.
Old Jan 12, 2007 | 12:04 PM
ttrank's Avatar
Grocery getter
No, if you drove it nice for a while, the ECU will learn that and adapt. It may not all be in your head. Now that you have re-set it it's more how the car should be.
Old Jan 12, 2007 | 12:49 PM
kpopseven's Avatar
yo what is the difference between taking off the battery cable and doing the pumping methoid ?
Old Jan 12, 2007 | 12:51 PM
cato's Avatar
End result is the same. Battery disconnect takes a few hours, pedal method resets it in just a coupe of minutes.
Old Jan 12, 2007 | 12:53 PM
chobble19's Avatar
battery disconnect takes a few hours!? ive done it within 5 minutes not even
heres another reset link https://g35driver.com/forums/faq-diy/6538-ecu-resets.html
