G35x tranny in the cold
Old Jan 12, 2007 | 10:37 PM
GEE35FX's Avatar
Originally Posted by DaveB
Prolonged cold start idling is BAD. It is far easier on the engine and emissions compontents to warm up as quickly as possible. The correct cold start procedure is to start the car, let it idle for 10-30 seconds and start driving at a light throttle and keep the rpms below 3000rpms.
Extended cold start idles:
1) wastes a lot of gas due to the overly rich fuel mixture
2) doesn't adequately disperse heat throughout the motor
3) will foul/clog catalytic devices far quicker
4) will foul 02 sensors
5) break the engine oil down far quicker with fuel hydrocarbon
Excellent answer Dave , I agree 100%. I feel it is very important to keep the RPMS below 3,000 until it is up to operating temperature.
Old Jan 12, 2007 | 10:39 PM
DaveB's Avatar
Taken from Hyundai http://www.hyundai.co.in/betterdrivi...name=customers
Warming up the engine: Though it is very important not to start driving before your engine is warmed up. Do not warm it up with too long idling - 60 to 100 seconds is usually enough time to allow your engine to idle. A cold engine will warm up faster when the vehicle is being driven than when left to idle for long periods of time. When the weather is unusually cold, remember to drive at slower speeds for a few miles to give your car time to warm up.
JD Power http://www.jdpower.com/autos/content...cle.asp?id=129
Don’t warm up your vehicle. Modern engine management systems do not require an extended warm-up period before driving in cold weather. Even on the coldest morning, running your engine for 30 seconds is all you need before your vehicle is ready to drive. (This is just enough time for the oil to circulate throughout the engine.) In fact, your vehicle will reach optimum operating temperature much faster when you are driving rather than when it is sitting at idle. Today’s engines are designed to run most efficiently and with the lowest emissions when warmed up, so the goal is to reach operating temperature as soon as possible. However, during the first few minutes of driving when an engine is “cold,” try to avoid sudden or severe acceleration.
Tree hugger site
http://www.eartheasy.com/live_fuel_e...nt_driving.htm
Old Jan 13, 2007 | 08:16 PM
jimmyc13's Avatar
Cool...thanks DaveB. I wasn't doubting you...just wanted to see where it came from, since I hadn't heard it before...those links help a lot!
Old Jan 13, 2007 | 08:40 PM
RetAF's Avatar
Believe it or not, this is often covered in owner`s manuals (gasp!). Of course, nobody ever reads those things. No plot and no sex!
seagrasser
May 3, 2022 09:43 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Jcruzg35
Sep 26, 2015 04:47 PM
Claudiu
Sep 26, 2015 01:04 PM
vstring
Sep 11, 2015 02:50 PM
