Removing Door Panels on G35 Sedan???
Old Jan 12, 2007 | 06:52 AM
nalinc23's Avatar
Does anybody know where to find a walkthrough for this? I've never done it and I need to soon! THanks a lot
Old Jan 12, 2007 | 02:29 PM
ballisticus's Avatar
Just carefully pry up along the bottom edge of the plastic strip along the door handle. Under there you will see the 2 screws. You also have a small plastic square cover in the latch/lock area that has to be pryed out. There is another screw under there. After those are out, you can begin pulling along the bottom to remove the panel from the clips. After all of them are pulled free, lift the panel off of the window ledge and remove the electrical connectors to set it aside. Takes about 5 minutes.
Old Sep 8, 2012 | 09:04 PM
JFletch's Avatar
Can these panels be broken down into smaller parts in order to re wrap upholstery?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
will091195
Jul 27, 2015 09:19 PM
laksjd84
Jul 24, 2015 05:12 PM
Blakelyg35
Jul 24, 2015 08:51 AM
emorehs
Jul 17, 2015 09:45 AM
