300hp 350z AT!!! i need help!
Old Jan 19, 2007 | 03:40 PM
g35sedan5at's Avatar
well this is probably the wrong forum for this...lol...no wait, it is the wrong one, but i wanted advice from you sedan guys. do any of you know if a 300hp A/T 350z was ever made, my friend claims he has one but i dont know.
after someone answers this, mods can close the thread cuz i know this is the wrong place for it
Old Jan 19, 2007 | 03:42 PM
Mmagic76's Avatar
I'm pretty sure the special edition model had the 298hp motor. Released in 05 or 06... could be called the 20th anniversary? (I'm just pulling words here).
ORANGEBSRT's Avatar
the '07 auto comes with 306. the '06 comes with 280 if i'm right.
Nismo G's Avatar
Yeah its possible, but lots and lots of engine work is needed. It would cost about 15 grand prolly.
-sean
Old Jan 19, 2007 | 03:50 PM
no no. my friend has a convertable 35th aniversary 350z Automatic...he claims 300 hp, i said a/t's come with 280, he said for 30th the a/t's came with 300? anyone can back this up???
Old Jan 19, 2007 | 03:52 PM
Nismo G's Avatar
Originally Posted by g35sedan5at
no no. my friend has a convertable 30th aniversary 350z Automatic...he claims 300 hp, i said a/t's come with 280, he said for 30th the a/t's came with 300? anyone can back this up???
Oh, yes it comes with 300 on the aniversery edition.
-sean
Old Jan 19, 2007 | 03:58 PM
k thanx
Old Jan 19, 2007 | 04:00 PM
so can i say its possible to get a manual engine with 300hp and connect it to my a/t trans
Old Jan 19, 2007 | 04:07 PM
Nismo G's Avatar
Well yes and no. The reason he has more HP is because his redline is also at 7200 RPMs (due to the rev up motor) where your auto transmission only redlines at 6700 RPMS (non rev up motor) so he has 500 more RPMS to produce that extra 20HP. Now if you have a ECU reflash so that your RPMS go up to 7200 then you would be able to say that you have just about the same amount of HP as he does.
You also want to take into factor that its not real safe to run a non rev up motor that high (7200 RPM) unless you have done some internal engine work. The non rev up can rev that high its just not real safe...if you do internal engine work then you will producing more HP anyways since the metal is lighter and what not....
Old Jan 19, 2007 | 04:28 PM
ttrank's Avatar
Grocery getter
I thought only the 6MT's came with the 300hp rev-up motor?
Old Jan 19, 2007 | 04:30 PM
Nismo G's Avatar
Yeah your write...whats the question though?
Old Jan 19, 2007 | 04:32 PM
ttrank's Avatar
Grocery getter
The question in the 1st post was is there a 300hp AT 350Z? I don't think so but may be wrong.
Old Jan 19, 2007 | 04:33 PM
rookie's Avatar
No rev up motor G or Z has ever been available with a 5AT.
Old Jan 19, 2007 | 04:38 PM
Nismo G's Avatar
No the aniversery350z 6MT is 300Hp. The aniversery edition 5AT is 287....
No one has a 300HP stock auto.
-sean
ttrank's Avatar
Grocery getter
What is the hp/tq rating on the 5AT Z?
