How do you remove wiper ARMS (not just blades)?
Old Jan 31, 2007 | 05:55 PM
dudlet's Avatar
Question How do you remove wiper ARMS (not just blades)?
I have a rattle at the base of my windshield. I found an Infiniti TSB that talks about removing the cowls just below the windshield on the outside. The first step in this process, however, calls for completely removing the wiper arms so you can then take off the cowls.
I'm afraid to do this without screwing something up. Can somebody tell me how to remove them and how to put them back once I'm done? Thanks!
Old Jan 31, 2007 | 06:13 PM
ttrank's Avatar
Grocery getter
Socket and ratchet or wrench should do the trick.
FYI - I have had those panels out and you don't have to take off the wipers.
Old Mar 27, 2008 | 09:35 PM
MareBear's Avatar
Can you possibly direct me as to how to change the wipers (not just replacement of the blades). I'm having difficulty doing so and I want to put on my Bosch's on, but don't know how to take of the stock ones.
Old Mar 27, 2008 | 10:03 PM
G35Ian's Avatar
sometimes the wiper arm will seize on the stud...if you get a small propane torch and heat the stud and arm a little bit it should pop off if you apply some pressure where the arm pivots, if that does not work a light tap with a hammer will get it loose...of course that is after you remove the nut first...GL
Old Mar 27, 2008 | 10:21 PM
MareBear's Avatar
thanks for the response ... so how do you remove the nut then? i just need to take the blades off to install the new ones.
Old Mar 27, 2008 | 11:06 PM
Tollboothwilley's Avatar
you do not need to take the wiper off to change the blades.
Changing blades is simple: lift up wiper arm, rotate just the blade, and pull up. Should pop the whole blade off. Then you just slide out the old insert and slide in the new one.
I believe the nut holding on the wiper arm is 14mm. Use a little leverage and this should come off with no problem. As for the blade being stuck on the notched bolt, apply upward pressure right beside the bolt and it will come up. If you try to lift up the whole wiper arm you will never get it off without possible issues.
Danielek
May 1, 2022 01:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
TNRocker
Sep 21, 2015 08:36 AM
