Stagered offset on a sedan
Old Nov 25, 2003 | 06:30 PM
SkyLine350GTs's Avatar
Is it possible to put wheels on the 04 sedan with a stagered offset like the coupes.
I am thinking Volk LE-37's T 19x8 front, and 19x10.5 on the back (i want that big phat lip on the back).
I would like to run as wide of tires as possible on the back. I see alot of people have no bigger than 245 width tires on the sedan. Is that the max size, if not i would like to put 275's on the back.
Also what would be the best wheel widths and offsets for the sedan for the Volk LE-37 T's. thanks for any info.
High Point NC
04 G35 6MT Sedan, Diamond Graphite on Black.
Arrived on 10/20/03
Mods include.
20% tint
INJEN CAI, black
clear bra
clear corners
Rip 2002 Altima 2.5s blk/grey 5/30/02-10/7/03
Old Nov 25, 2003 | 07:02 PM
pestilence's Avatar
Re: Stagered offset on a sedan
There has been some discussoin reguarding this subject, If you have an 03, I would say no, becuase I personally put differnet size tires on my G..and the SLIP light came on... although I think it "recodnized" the chagne now.. the dealer still warns against this.
..Anyone with 04 knowlage?
Old Nov 25, 2003 | 09:51 PM
ryoken's Avatar
You see a max of 245's for those that keep the same size, because anything wider than that is pushing it as far as clearance in the front. Officially, Infiniti says 225's are the widest allowed in the front.
As for wider back tires, the important thing is the diameter of the front and back tires. They need to be really close. Use this Tire Size Calculator to find some sizes that have nearly the same diameter.
The big thing is the VDC system. If you get too much of a difference between the front and rear tires, the smaller tires will spin faster than the larger tires and the system will think some of the wheels are slipping and constantly be attempting to correct the "problem" by applying the brakes to the smaller/faster tires.
Old Nov 25, 2003 | 10:45 PM
GurgenPB's Avatar
skyline350GT,
There is NO WAY that you are gonn ae a ble to fit a 10.5" wide rim int eh back. 9.5 is pushing it and you need to have an incredibly precise offset, and a very large one, +50 or so. Believ me, use the offset calculator and you'll see. I put hours of research into this. Make sure thewheel diameter is withing 1% of one another. Use the tire size calculator for this. As a result of this research, I am getting 8" +40 in the front, and 9" +45 in the back. And here is the proper size (these are smaller than stock but are within 0.1% of one another) for tires: 245/40-18, 275/35-18.
GurgenEDIT: i just checked the LE37T specs: the highest offset number is +42. If you put this wheel on a sedan - it will stick WAY out of the fender. Your tire tread will be directly under te outside fender edge. Way too wide.
<P ID="edit"><FONT class="small"><EM>Edited by gurgenpb on 11/25/03 07:55 PM.</EM></FONT></P>
Old Nov 26, 2003 | 06:15 PM
G35_PR's Avatar
I have the 18" coupe wheels with the pilot sport 225/45 front 245/45 rear and no VDC or Slip light come on. The offset is different and the rear wheels is a little stick out but look good
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
reaper76
Aug 5, 2015 10:13 AM
