Block Heater
Old Feb 7, 2007 | 05:49 PM
Mmagic76's Avatar
Block Heater
Ok, it's been crazy cold here lately (-20 degrees celsius) and I just wanted to know how to check if my block heater is working properly (besides seeing a small spark when I plug it in)?
Does it heat the oil or rad fluid or both or what?
I haven't found much on here or the service & owners manual but any info would be appreciated.
Thanks.
Old Feb 7, 2007 | 08:23 PM
35bills's Avatar
The "block heater" in the sedan heats both the engine oil and the coolant.
4 hours max is the most time you would need to warm up your car. Get a timer so you don't have to run in and out just to unplug/plug the car.
Most times I will not use it until the outside temp would fall below -10C.
You will know the difference when starting your car. It will be much easier to turn over...
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
B03Sedan
Sep 22, 2015 10:37 PM
