Nismo LMGT4 19x8.5 +25 fit a sedan?
Feb 10, 2007 | 01:30 AM
Sorry if this is an easy one. Would a 19x8.5 +25 all the way around fit a sedan? I ask because I have 2 staggered sets of the 19" Nismos, 1 new and 1 on my FX. I would love to run the 19x9.5 all the way around on my FX but would than have 4 19x8.5s, not sure if this size fits a sedan or not.
Thanks for any input
Reply 0
Feb 10, 2007 | 01:37 AM
Nope, wrong offset for the sedan.
If you want to run a 8.5 all around you will need +38 to +40 for a nice fit.
Reply 0
Feb 10, 2007 | 01:39 AM
Front too wide?
Looking at ttranks set up his rear is a 20x10 +40 the Nismo 8.5" +25 is 4mm less but for the front it's 15mm wider than his set up.
Oh well, guess I'll just sell this other set.
Reply 0
Feb 10, 2007 | 01:43 AM
It will fit, but it'll just stick out really bad in the front and if your not dropped with some negative camber, the rears will stick out too. The front's aren't too wide, 8.5" is perfect for the front, just the offset is too low.
Reply 0
Feb 10, 2007 | 01:56 AM
Yeah that's what I meant by wide as in stance. Thanks for the info guys.
Reply 0
Feb 10, 2007 | 12:55 PM
You can also run 35 offset as well and run 245/255 tire and it will fit. I have the z track wheels which are 8.5 w/33 offset and run 235/45 without any problems. Probably could use a 245/40 as well.
Reply 0
Feb 10, 2007 | 04:09 PM
fitting is one thing...stance is more important....thos are sick wheels, just will stick out too much.
Reply 0
