what can i do
Old Feb 10, 2007 | 10:12 PM
thelurker29's Avatar
what can i do
ok guys i got a new set of rims but heres the problem...i got 18X10 rear and 18X9 front....the thing is...in the rear its going to stick out WAYYY to much...and im not really feeling it..not to mention i want to be able to drop it more later on AND my car is going to be getting dirty out the ***
is there ANYTHING i can do to make it sit inside the damn fender???? PLEASEEEE let it be so
Old Feb 10, 2007 | 10:30 PM
R2 V35's Avatar
Yes! get rid of the wheels!
Old Feb 10, 2007 | 10:34 PM
atlast's Avatar
time for wide body =D
thanks ...for the ...help....
Old Feb 10, 2007 | 10:40 PM
Chico's Avatar
be more specific. what are the offsets? and what tire sizes do you want to use? whoever sold you the wheels should have recommended the right application for your car.
Old Feb 10, 2007 | 10:42 PM
kenasaki's Avatar
nothing more to say man. u got 10" wide wheels, it wont stick out that much, it'll just be flushed witht the fender. i have 19x10 in the rears, and it looks perfect and its lowerd. well, once i get a camber kit, it should sit perfectly with the fender.
so, basically....either get rid of it, or deal with it.
Old Feb 10, 2007 | 10:49 PM
so what DOEs the camber kit do..?
would it help me some? and what offset are you running 636
ive never understood what camber kits are for or if it would help me in this situation
Old Feb 10, 2007 | 11:20 PM
G35Papa's Avatar
Google camber kit.
If you need help here, like whats been said already, you need to offer up more detail to get suggestions.
Old Feb 10, 2007 | 11:37 PM
VQ Hotness's Avatar
A camber kit will help correct the angle of your rim once you lower your car.
When you lower your car the top of the rim is pulled toward the car the lower you go to the ground.
Also Im pretty sure you might need to get a spacer up front.
Old Feb 10, 2007 | 11:59 PM
crap your for real?? so basicvally im going to have to make the FRONT rims stick out as well?
Old Feb 11, 2007 | 12:09 AM
Chico's Avatar
^^^are you dyslexic??????? for real!!!!
Old Feb 11, 2007 | 01:28 AM
VQ Hotness's Avatar
What offset are the rims coming in ?
