gas smell
Old Feb 15, 2007 | 12:39 PM
CanadianZ's Avatar
gas smell
First off I have a 2003 Sedan w/ 85,000KMS. I am in Canada and it has been only 5 degrees F for like 10 days solid. Once in awhile i think I smell gasoline. I am a diesel mechanic so i have checked for external leaks and found no signs. Had the plenum cover off and everything. It could just be vehicles around me but i have smelled it about three times in a month.
Any ideas. Also my car gets pretty bad mileage but i think thats expected of these cars.
Thanks
Old Feb 15, 2007 | 12:45 PM
Msedanman's Avatar
O.F. Administrator
Check around the filler neck and related piping... On some of the early models, there was a recall on the fill pipe way back which may not have been done on your ride.
C.
Old Feb 15, 2007 | 01:13 PM
ttrank's Avatar
Grocery getter
^+1
Have you had the fuel hose recall done? You might have a leak.
Old Feb 15, 2007 | 01:41 PM
CanadianZ's Avatar
thx
thx i will check. is there any way to check online?
Old Feb 15, 2007 | 02:46 PM
Msedanman's Avatar
O.F. Administrator
All the info you need is here:
http://www.infinitihelp.com/
C.
Old Feb 15, 2007 | 02:53 PM
RetAF's Avatar
Since you are a mechanic, you probably already know not to overfill your tank. Saturates the charcoal filter and causes you to smell gasoline for a while after filling tank. I just threw this in since you said it happens a couple times a month. Does wifey or sig other or anyone else take your car to the gas station?
Old Feb 16, 2007 | 04:18 AM
CanadianZ's Avatar
no, only me. no one else drives my car. first time it clicks i stop filling so i don't think that should be the issue.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Blue Dream
Dec 5, 2015 10:56 AM
prinny
Nov 22, 2015 11:07 PM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
