Found this BBK kit for Sedan!!
Old May 21, 2007 | 11:59 PM
ttrank's Avatar
Grocery getter
They are local and don't have a good rep around here. (Just an FYI)
Old May 22, 2007 | 03:21 AM
Tunerz_Store's Avatar
interesting.
Old May 22, 2007 | 10:23 AM
QuadCam's Avatar
Originally Posted by GeeWillikers
DO NOT SCRIMP ON BRAKES.
You can cut corners many places, this isn't one of them.
there is nothing wrong with Wilwood. They have been around alot longer than most of these newbie brake companies.
Old May 22, 2007 | 12:38 PM
dklau33's Avatar
There's absolutely nothing wrong with wilwood but this isn't an official wilwood kit. It's just a kit that uses wilwood calipers put together with other components to make a economical package. Who knows how much R&D went into this for our specific vehicles. Could be great, could be crap. If I wanted a wilwood kit, I would stick with the actual factory kit where I know wilwood themselves did the proper R&D and get it right the first time.
http://www.tceperformanceproducts.co...s.pl?record=22
Old May 22, 2007 | 01:41 PM
ttrank's Avatar
Grocery getter
Wilwood makes good kits and their parts here are good.
Old May 22, 2007 | 03:26 PM
accordhybrd's Avatar
Really the only thing I see that would make a difference and is not Willwood is the brackets. The rotors are fine as long as they are the same thickness of stock rotors and pads are pads.
What's the problem?
Old May 22, 2007 | 04:03 PM
GeeWillikers's Avatar
Walking The Fine Line...
Originally Posted by trey.hutcheson
Hey, this is a technical discussion. Get out.
Old May 22, 2007 | 05:38 PM
ttrank's Avatar
Grocery getter
K-Sport just came out with 13" and 14" kits for our car. I am looking into their 8pot 14" front and 6-pot 14" rear. That will do the trick!
Old May 22, 2007 | 05:43 PM
redlude97's Avatar
What's the problem?
you would have to make sure the calipers are sized correctly also the brake bias isn't screwed up
Old May 22, 2007 | 05:47 PM
ttrank's Avatar
Grocery getter
What's the problem?
The problem is also part quality and fitment. They made a custom kit (like this one) for a shop I know and it took them 5 tries to get it right.
That is all I know.
Old May 23, 2007 | 07:34 AM
ma_sha1's Avatar
I have this 4-pod caliper set up with 13.6" 2 piece-rotors for my sedan,
The brackets fits well.
Jusseth
Sep 13, 2020 12:25 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
teamghost
Jul 28, 2015 04:52 PM
mushu
Jul 15, 2015 03:55 PM
