Question about y pipe after installing coupe middy
Old Feb 19, 2007 | 09:10 PM
dunglan7's Avatar
I was trying to install a coupe mid pipe on my sedan and one of the nuts was stripped. So I took it out to a mechanic shop and told him I was willing to pay him a couple of bucks just to take off the nut. Well he end up cutting the whole nut off along with the stud. So now I can only hold on the y pipe and mid pipe with one stud. So do you guys think that I should go to a specialty shop to get them to make a hole where the welded stud used to be? I figured that they would charge me about $50 or should I upgard to a aftermarket y pipe? Will a aftermarket y pipe help our sedan any?
Old Feb 19, 2007 | 09:49 PM
G35m@'s Avatar
I've been told that the aftermarket Y-pipe does nothing for the sedan - I have no hard evidence to back this up.
Old Feb 19, 2007 | 10:18 PM
godmans's Avatar
In terms of a logic standpoint, whoever told you must be doing things thinking "outside the box"....
Most of users here report no gain from the coupe middy or rear section but do benefit from y-pipe (even though most of them back it off with a butt dyno).
Saying an aftermarket Y does nothing ~ there is no point in touching the catalytic-back exhaust
Old Feb 19, 2007 | 11:15 PM
G35Papa's Avatar
Have it drilled out and get a bolt and nut to tighten it back up. That would be your best buck.
I would say (butt dyno) that when I had a Y, I benefited from better flow at higher speeds and lost a little bit on the bottom end torque. I never dynoed it to get real numbers before and after though.
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
johnjohn077
Engine - Exhaust
Oct 2, 2015 06:41 PM
newg37
Jul 26, 2015 09:32 AM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
