does G35 have fuel cutoff switch
Old Dec 2, 2003 | 06:56 PM
theskipps's Avatar
Does anyone no whether the G35 has a fuel cut off switch.As bad as i hate this say this i ran out of gas.I put the gas in , the car cranks and shuts right off.Any help would be appreciated.
Thanks
Old Dec 2, 2003 | 07:34 PM
Msedanman's Avatar
O.F. Administrator
Re: does G35 have fuel cutoff switch
There's no such switch that I've come across, like the ones in the trunk of my Mustangs and Contours, and there's no mention of any fuel pump reset switch in the Coupe ESM either.
Only thing I can suggest is to prime the pump and the system first by turning the key on for a minute or 2 b4 trying to start it.
Did you put in a few gallons at least? or just a little. It may need a few to prime the system properly.
Good luck
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Dec 2, 2003 | 07:40 PM
shodog's Avatar
It sounds like you have air in the line that's why it will run for a bit then sputter out. I am not sure if there is a pressure relief valve on the fuel rail or not. My SHO has one. recently my SHO vaporlocked. I was able to turn the key on, pressure the line then let the presure off at the fuel rail. I did this a few times and then my SHO started and ran with no problems.
Jim
'03 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Dec 2, 2003 | 07:53 PM
ABQ_G35's Avatar
I thought that was a requirement on all cars in the US?
Brilliant Silver/Graphite '04 Sedan/5AT
wonderizm
Sep 24, 2015 03:09 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
brian_z
Jul 22, 2015 09:19 PM
vstypicals
Jul 20, 2015 10:55 PM
