I forgot something...
When I got off the dyno. For the first mile my ABS, VDC, and Slip light were on. Then they all went off. Should I be concerned??? VDC was off during dyno pulls.
Originally Posted by absolutg
no you shouldn't. the dyno messes up some stuff but as long as they go off on their own you should be ok
C.
^+1
Your car may think there is a problem with the VDC and ABS systems since the rear wheels are turning and the fronts are not. It will go back on its own.
Next time just make sure to turn off VDC before you make a run.
Originally Posted by ttrank
^+1
VDC was turned off though!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Greenlawnracing
Engine - Intake/Fuel
Feb 21, 2016 10:39 AM
dimentio1
Aug 16, 2015 11:47 AM
