tranny question?
Feb 26, 2007 | 04:15 AM
Do these trannys have a filter? If not is it better to get a full flush or just a drain and fill?
Reply 0
Feb 26, 2007 | 04:20 AM
drain and fill it to be safe, you wont get all the old fluid out with a drain and fill because the pan only holds 5-6 quarts but if you empty the pan every 15k you'll get all the new fluid in there eventually.
-GP-
Reply 0
Feb 26, 2007 | 11:55 AM
Why isn't it safe to get a full flush?
Reply 0
Feb 26, 2007 | 01:14 PM
A full flush is fine too when done right, it's just not worth it IMO. I have always believed in just changing the fluid more often and DIY.
Reply 0
Feb 26, 2007 | 01:15 PM
Quote: A full flush is fine too when done right, it's just not worth it IMO. I have always believed in just changing the fluid more often and DIY.
yeah, but how many people really know how to do it right...?
-GP-
Reply 0
Feb 26, 2007 | 01:31 PM
Quote: Do these trannys have a filter? If not is it better to get a full flush or just a drain and fill?
It does have a filtering media but it would be better described as a screen. Unless it is torn then it can just be wiped down with the pan removed. I just use brake cleaner to clean it along with the pan and magnets. It is a replaceable part if it is torn or damaged.
Reply 0
